I have a bit a problem I would love to hear your advice on. I have a 37 LG LCD TV (37LC7D) and have owned it since about last Sept. This has been a great TV and I have had zero problems with it. I came home today, turned it on, and noticed the picture brightness flickering a bit. Then the screen went black but I could still here sound (though the TV speakers). Then the set just powered itself off. Tried to re-start it, and similar thing. Stays on for a bit (less than a minute) then goes black, with sound. Then just powers off. I let the TV sit for a while, and then tried it again. The picture lasted for a while (maybe 2 mins) then brightness abruptly faded and then entire picture started to flash for about 30 secs, then completely went black but still with sound. After about 10-30 secs the set just powers completely off.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic:
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37 in. HDTV LCD TV My screen seem to over heat, Goes blank, but TV is still on. then comes back on for a few seconds, then again blacks out
It sounds like a problem in the high voltage circuit. Had a similar TV set which had the same problem. When there's power leaking from the high voltage circuit, these TV's will tend to cycle on and off. Voltage leaks are mostly caused by accumulated dust for the most part.
Jan 31, 2011 | LG 37LC7D 37 in. LCD HDTV
Looking for a tv stand for LG 37LC7D 37 in.
I would suggest you check ebay, or shopjimmy.com.. there was one at shopjimmy.com but I am not sure if it is still available.
good luck!
Aug 25, 2010 | LG 37LC7D 37 in. LCD HDTV
Truble switching on tv
its repair immediatly its a power supply problem,
Apr 14, 2010 | LG 37LC7D 37 in. LCD HDTV
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
Broken LCD
well dont trash it.. it will cost you more to fix it than it will take to buy a new one what you can do is search for another broke one with a good LCD screen or most tv repair shops will buy it from you for parts on the last LCD tv i sold to a repair shop for a 26" thay gave me $100.00 dont know how thay are in your area but it is worth looking into.
Nov 16, 2008 | LG 37LC7D 37 in. LCD HDTV
Power went out on LG lcd tv
Those units usually have a main board that all the functions are centralized on. If the LED comes on then your power supply is operating (at least no shorts). But the main board will most likely be the problem.
C-Dog
Feb 10, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
