Need list of codes for panasonic plasm tv - Televison & Video
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash radidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programing your remote can be found here: http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Our panasonic plasms tv turns itself off after about 30 - 40 seconds
It sounds that the Y buffer board has the fault. Repair to plasma TVS is really a skilled work. For more information, check the link ttp://electronicshelponline.blogspot.com/
Nov 18, 2013 | Panasonic Televison & Video
46 plasm tv
Likely a bad power supply in the set--only boards are sold so voltage into the supply and out needs to be the first thing that is checked.
May 04, 2012 | Panasonic Televison & Video
Need code for a panasonic tv
Each remote has its own set of codes and supports only a very limited number of tv models. If your tv isn't listed then your only option is to try all the other codes listed for the manufacturer (Panasonic in your case) in the hope one of them will work. If none of them work that the remote isn't supporting it, simple as that.
Jun 08, 2010 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
My panasonic plasm tv wont turn on and the red light is flashing
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.
Jun 02, 2010 | Panasonic TCP50S2 50 in. TV
TV WILL NOT COME ON, RED LIGHT IS LIGHTING UP BUT TV WON'T COME ON, SOMETIMES COMES ON
i have a panasonic 42" plasm tv and te power button just binks aND THE TV WILL NOT POWER UP
Oct 01, 2009 | Samsung Televison & Video
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Jun 03, 2009 | RCA Universal Remote Control
Panasonic Plasma TV Repair info
Hi rob,
Please provide the service manual to easy find the correct service manual you want. Or you can try to these site to get free plasma tv repair service manual:
http://www.fastrepairguide.com
http://www.plasma-television-repair.com
Hope this will help you to get what you want.
Have a nice day,
Ken
Mar 31, 2008 | Televison & Video
Code for panasonic tv
ineed the code for a panasonic ct-27sx12af
Dec 01, 2007 | Panasonic CT-27G11 27" TV
Plasms tv
Hello
Do you have a back-UPS?
May 30, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
