Block other computers outside your home - Computers & Internet
    Problem Solver:
  • 10 Answers
Are you refering to a wireless internet router? If so many have the ability to restrict by mac address and/or add a password protection. Each router is different, so refer to that documenation.
Posted on May 01, 2008
Why does my sharp AF-06CSL window unit leak inside home? It is leveled and tilted down outside.
Blow out the drain from the outside. Something probably is blocking the drain causing it to overflow into the house
Aug 12, 2016 | Sharp Heating & Cooling
The school Phantom Technologies has block Facebook and i cant get on. Every day i fine new sites or proxy's and she keeps blocking it .
Requires:
An always-on home computer
A home router that supports dynamic DNS
A school policy allowing you to use an ssh client, or your own computer (i.e. laptop).
1) Have your router obtain a DNS name (research dynamic dns. And register for a name and setup your router)
2) Install the OpenSSH server on your machine. Verify you can connect to it at home using another computer.
3) Verify you can ssh to your home machine from the "outside" (i.e. try from a Starbucks).
4) Finally, see if you can connect to your home machine from school. If it's blocked... try changing the port your SSH server listen to. (i.e. change from port 23 to something higher than 1024). If it still doesn't work... see if you can "see" your home machine at all (i.e. ping ).
5) If you can indeed ssh to your home computer, then setup an ssh tunnel on port 80. Now, all your browser traffic will go thru your home computer and not thru the school's network.
Mar 08, 2011 | Computers & Internet
Hi my dyer is not dying my cloths, i have power to it .
Is your outside vent may be obstructed / blocked. Mice love to build nests in the actual dryer vent tube leading outside of the home. Check this vent pipe. for blockage of any type.
Please remember to rate my solution. Thanks and Good Luck!
Jan 24, 2011 | Whirlpool WED6200S Dryer
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
Copper lines outside are visibly frozen. Unit is
you have a restriction of air ,change filters and clean coils that should do it make sure nothing is blocking return vent
Aug 22, 2009 | Heating & Cooling
Unblock blocked websites
It depends on where you're at and how they are blocked. Generally the solution is to set up a proxy server that is not on a blocked network that you can access from over the internet. For example, if you have AT&T U-verse internet at home, at to access MySpace from work, where it's blocked. You could set up a proxy on your home computer, configure your AT&T router to pass traffic from the internet to that proxy, and then from your work computer, you would configure your browser to use your home computers IP address as a proxy. What this does is routes all traffic from your work computer to your home computer. If you utilize SSL for this connection, it's 100% encrypted and your employer only sees you accessing your home computer, they can't see what data is passing between.
Feb 11, 2009 | Nokia IP 350 Firewall
Can i cover my outside house vents in the winter?
you should never cover any vents, they are there for a reason, to keep you safe from fumes, damp, etc.. (If talking about vents that are outside you home). If you are talking about appliance vents then you run the risk of them breaking if you cover the vents, due to overheating
Vents that are outside the home including boiler vents etc... exhume all of the carbon dioxide that is bad for you. Vents that are there to stop damp, if blocked may cause you to have a problem with damp in the future.
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag dryer
it sounds like there is no air flow check outside of home where vent exits house there should be strong air flow it either a blocked venting or a bad blower fan in the dryer most likely blocked venting start outside then work your back to the dryer if no air flow outside remove venting from the dryer ifgood air flow here the vent is blocked if not blower fan most likely broken these blower fans drive hub round out on the motor shaft of the motor but it would be very loud this should fix it for you thanks kevin
Sep 30, 2008 | Whirlpool Dryers
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
