Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
WILL NOT RUN (KSM90WW)
IS THERE A RESET ON THIS UNIT. I TOOK THE BACK PIECE OFF AND UNHOOKED THE CONNECTIONS ALLOWING ME TO REMOVE THE ELECTRIC CHORD. THERE WAS A GREEN, WHITE, AND BLACK WIRE CONNECTION WAS ALL I TOOK LOOSE. WHEN I REATTACHED THE WIRES AND CHORD THE THING WOULD NOT WORK. I HAVE CHECKED ALL OUTLETS AND THEY ALL WORK.
  • THEADORE May 01, 2008
    this problem still exists. please assist........
  • 65 Answers
Theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
Posted on May 05, 2008
  • CJ C
    CJ C May 09, 2008
    theadore I am trying to assist you. but first I need to know exactly how you have it connected. it sounds is if something is not making contact with the motor contacts or something is not connected right with the power.
Where can you purchase these items for the kitchenaid food mixer model no.ksm90ww
That is a Wire Whisk, I carry them in stock in New Zealand but I doubt that will help you. What country do you wish to purchase it in?
Jan 08, 2015 | KitchenAid Food Mixers
Question: How do you put the string and spring wire clip back into the planetary assembly so that it won't interfere with the gears by coming loose?
I have repaired/reconditioned a number of K5-A mixers and have never encountered the parts you have described. They are not in the Service Manual. Try reassembling without those pieces.
Jul 24, 2014 | KitchenAid Food Mixers
Well, I was attempting to replace my speed lever. In the process I removed the back cap (electrical circuit board) and the two screws on the side (flat, springs with magnets attached). After I replaced...
Hello Lora,
I understand that you took you speed lever out to replace it and you took the brushes out of each side of the unit. The reason that the unit will not start is more than like the brushes are not installed the proper direction.
1. Unplug the machine
2. Shine a light in the hole on the hole on the side of the unit. You will notice a notch or a piece sticking out.
3. Take one of the brushes (magnet looking things) put the notch and the cut out in the same corner.
4. Repeat the samething with the other side.
5. Plug in and check and see if it runs
This should solve your problem with the brushes. IF you have any more questions about this mixer please post it to this discussion.
THank you for choosing FixYa.com
Justin
Mar 13, 2011 | KitchenAid KSM150PS Artisan Series Stand...
We have model # KSM90WW. The problem is that the mixer portion hangs down too far into mixing bowl, thus making the mixer "buck" when mixing. Have tried to tighten everything that can be...
Till the top back and look into hinge area. You will see a large set screw that controls how far the head drops. Try turning the screw counter clockwise 1/8 of a turn.
Feb 18, 2011 | KitchenAid Classic Stand Mixer
My DeLonghi DSM800 when running sometimes stop for a second and then starts up again. It also seems to speed up at times and almost sounds like it is skipping a gear or something. Any ideas.
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 03, 2010 | DeLonghi 800 Watts Cucina DSM800 Stand...
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Runs fast for a few seconds , then runs very slow
Jan 06, 2009 | DeLonghi DSM7 Stand Mixer
Kitchenaid 350 stand mixer power problems
I'd check the brushes. The big black screws on the side of the motor casing, easily removed, but becareful when you put them back. Here were some instructions from another site that helped me get them back in right:
The brushes in my model KP50PSBU must be insert in a particular manner in order for it to work correctly. If you remove the brushes and shine a flashlight into the hole, you should see a small detent or "stop" in one corner of the hole. Its a square hole. Match this corner with the corner of the brush which is shaved off. The brush is not square; it has one corner shaved or smoothed down. This allows the brush to fully extend into the hole. If the brush is inserted any other way, it will not contact the motor and will not run.
Jun 01, 2008 | KitchenAid KSM50PR Professional Series...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
211 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
