Question about Nintendo Super NES Console
How to properly connect the original nintendo to your tv
I got an old game system, i was just wondering if it i got all the wires right, or if I got them all , at all. I have the power plug and the red/yellow plug (A/V)...Do I nee to have the RF Switch plug (White)? PLease let me know. I got it at the thrift store for $35 with a **** load of games. The whole thing looks brand new. Please let me know.
thanks
    Problem Solver:
  • 10 Answers
As far as I know, you should be fine. Just plug it into a tv to make sure though.
Harris
Posted on May 01, 2008
I found my old N64 console, I only have a rf cable with it but when everything is plugged in i cannot find the channel. My TV is quite old. People say it's 3/4 but i try these and it didn't...
Nintendo 64 AV to TV Hookup
Important Note:
We highly recommend you review the following precautions before you set up and operate your Nintendo system:
Important Safety Warnings & Precautions
Hardware Precautions / Maintenance
Game Pak Precautions / Maintenance
Precautions Concerning TV Screen Damage (Image Retention)
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo A/V cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting the each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo A/V cable into the "multi-out" connector on the back of the Control Deck.
After system is connected to the TV:
Insert Game Pak fully into the Control Deck.
Plug the Controller(s) into the front of the system using the left most port for Player 1.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It's often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play!
If after following these directions completely you are not able to view the game, try our Troubleshooting Tips.
Dec 26, 2012 | Nintendo 64 Console
I need to get my Wii and Wireless Router set up properly
Depends on how far you are from your router and the construction of walls . You may need to get an extender which acts as a relay place it somewhere between the original router and the downstairs location. If it is a smart tv, follow the directions for the tv and make sure the adapter in the tv is compatible with your router. Check the specs.
Feb 18, 2018 | Nintendo Wii Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
How do I plug in the super nintendo to my computer? I don't know which cable goes into the "out" place.
Computer Monitors
Nintendo home consoles are designed for use through home televisions and VCRs, using standard A/V, S-Video, component, or RF connectors (for older systems). Computer monitors typically do not have these connections. There are however two ways a hookup to a computer monitor could be accomplished:
With a PC TV Card:
A TV card inserted into your PC may allow you to connect your system if the card has the proper connections (such as RF, A/V, S-Video, component, or Coaxial). However, we have found that the image quality is not as clear as it is on a TV, in most cases.
With a Direct Connection (RGB or DVI Cables):
Nintendo does not manufacture any cables to make an RGB or DVI connection. While other companies may manufacture wires that can make this possible, we are not able to recommend them, as they are not licensed by Nintendo.
Oct 26, 2010 | Nintendo Super NES Console
I cant tune in my nintendo do you know what its meant to be set too
Hi your NES should have on it's right hand side 2 Audio Video inputs have you tried connecting it to your TV via Audeo Video Cable and selecting Video channel on your TV dont worry about using the old RF switch they are for older TV Units. Here is a picture of what the AV Cables look like http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-audio-video-cable-no-more-tuning.html
Jan 16, 2010 | Nintendo NES Console
New wires and it still wont come on my tv
ok buddie nintendo 64 is old so new wires with a old system might not work so there is your problem
Oct 07, 2009 | Nintendo 64 Console
Problems hooking up an original nintendo
super nintendo set up to a magnavox standard tv
Oct 02, 2009 | Nintendo Super NES Console
Denon 3808ci won't upconvert old video game consoles
Since the games are so old and the SNES is an ancient console most tv's are made for the newer ones/Wii, Xbox, ETc./ So The Tv May Require Certain Wires for the console to function correctly, it also may be that your wires for the SNES are corroding in side *( Copper Wires Etc. )
Dec 12, 2007 | Denon AVR 3808Ci Receiver
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Sep 17, 2007 | Nintendo NES Console
Nintendo Super NES Console Logo
975 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
