Question about AudioTrak MAYA 44 USB External Sound System
Trouble installing a maya44 usb audio device to my BPM studio software
Hi i have a problem trying to installing this device in to my BPM software i have windows vista i think this is the problem but i don't know for sure.. if u can help me out with this problem i'll app...............thankkkksssssssssss
  • walterdiaz_2 Aug 16, 2008
    i cant install the softwares and it shows that none of the usb slots work and they do..
  • 111 Answers
Download the updated driver for Vista from this link: http://download.esi-audio.com/?w=esi&p=40&g=2&l=en
Hope this helps and if does, please vote.
Thanks!
Posted on May 01, 2008
2 Suggested Answers
geokohler
  • 304 Answers
SOURCE: trouble installing a maya44 usb audio device to my BPM studio software
Did you disable the onboard sound device using the device manager. You can't have 2 sound devices active at the same time or it will cause conflicts. I'm pretty sure this is your problem, but if not feel free to contact me and I will help you diagnose you problem deeper.
George
Posted on Jul 19, 2008
What cable would I need to connect the audio output of a Yamaha Claviola to a Mac running Garage Band?
in order to make a good connection with digital audio i recommend using an audio interface i personally use a maya44 usb.
Feb 08, 2011 | Yamaha Music
Mini DV connected to Dell PC by 1394 cable
Open DISK MANAGEMENT,see if there is a Drive letter conflict (USUALLY with Mapped drive)
Jun 26, 2008 | Panasonic NV-GS4B Mini DV Digital...
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
Driver installation problem
Some computer firewire interface's don't work very well under Windows... However...
Make sure you follow the installation directions to the letter... especially in regard to whether the cable is plugged in while installing...
Also you MIGHT try installing the software in SAFE MODE.
Then in the audio editing software you often have to configure the audio in/out device.
This can realy be frustrating... I just fought a UA 25EX to get it to work and the problem was an incorrect switch to the sample rate.
May 24, 2010 | Behringer FCA202 - FireWire Audio...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Finding bpm studio crack/patch
To be honest BPM Studio aint worth Cracking anyway, it's **** in comparison to other DJ Software such as Virtual DJ.
Above all, I'd be very careful about what you ask for on sites such as this, as your basically asking someone to willingly participate in Software Piracy. Above that, Alcatech's BPM Studio uses Tight Anti-Cracking Procedures, and a cracked copy would be diabaled within days anyway.
Best off searching on Google using the following Keywords :
Freeware DJ Software Downloads
You'll get some decent full version / no limitation software that way.
Nov 16, 2008 | Computers & Internet
XP works GREAT, and Vista still has problems. So if you want a reliable compatible OS, switch back to XP and next year Vista should be good to go. MS is notorious for marketing Operating Systems before they are fully compatible. So, if you like problems and waiting for solutions, stick with Vista as it may work correctly someday soon.
Jul 19, 2008 | AudioTrak MAYA44 MKII Sound Card
Maya44 poor sound quality
Check the maya graphics card audio settings. there may be some improper audio setup. the Maya 44 card audio codec and filters are not supported by your OS. Your system configuration is good. there may not be any problem with Pc compatibility. only because OS audio codecs. try dowloading codecss for this audio rendering device
Dec 17, 2007 | AudioTrak MAYA44 MKII Sound Card
USB Midi Controller
the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. replaced them with the 2 USB ones from M-Audio, DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install.
Good Luck you can do this /Have a great Sunday and a safe one.
Dec 02, 2007 | Acer TravelMate TM3012WTMi (LXTAT06045) PC...
AudioTrak MAYA 44 USB External Sound System Logo
748 people viewed this question
Top AudioTrak Computers & Internet Experts
David Payne
David Payne
Are you an AudioTrak Computer and Internet Expert? Answer questions, earn points and help others
