Trying to receive a fax. Getting a message "processing has been cancelled due to an error" Gives me fault code 024-747. Help... what do I do???
    Problem Solver:
  • 7 Answers
If this is a Xerox fax machine, that specific error code states:
An invalid print parameter combination was set. Check the print data. For example, a custom size was specified, and [Paper Supply] was set to [Auto]. In this case, select the bypass tray.
Posted on May 01, 2008
    President:
  • 2,072 Answers
What is the make and model number?
Thanks
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
After I replaced toner, it continues to process "check toner". And now it says "toner is low" with the new cartridge intstalled.
Try turning it off and unplugging the fax machine. If you are receiving this error message on your pc, then it should be unplugged and restarted too.
May 03, 2011 | Office Equipment & Supplies
Trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled. Doesn't matter if we are faxing one page or multiple pages.
trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled.
Apr 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
Getting error message 999 when trying to go to my mail
The most common reason for receiving Yahoo Error 999 is due to some sort of bandwidth limiting system that Yahoo has put in place on their servers. Once you have exceeded your allotted bandwidth for a specific period of time Yahoo gives you this Error 999 message and doesn't allow you to access the service. People have primarily reported receiving this error when they try to access Yahoo Mail or Yahoo Groups, but other Yahoo services may also be affected.
------ source: http://forums.techarena.in/technology-internet/1112227.htm
Feb 22, 2009 | Yahoo Mail
Brother mfc 8220 gives error message check original but no paper jam exists.
I assume you're getting this error when sending a fax?
Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
If you are constantly having this error, get a phone repairman in to test your fax line.
Feb 06, 2009 | Brother MFC-8220 Fax
Lg vu internal error message displayed when trying to send multimedia message
Does it give an error code? That could help to better define the problem. Mine does this and then gives me "Internal Error 22"
I haven't been able to find out what causes it. What I've found works is when you get the internal error 22, go to your messages outbox. The message you are trying to send will be listed there and will probably still say "sending". Cancel sending. Then resend. I don't know why, but this has worked for me. Hope it helps you.
Dec 22, 2008 | LG Vu CU920 Cellular Phone
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
0009: Error during TX message
Guys,
I got the same problems and then I contacted our PSTN provider and they configured the route. Now it is working fine!
Jul 18, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
540 people viewed this question
jasbo
jasbo
