Question about Sony KDF-E60A20 60 in. LCD HDTV
Video Input Display Will Not Go Away
I've got a Sony KDF-55XDS955 and it has performed well the last few years. However, not the display in the top left portion of the screen that tells you the source for the video input will not go away. It used to display anytime you switched between inputs, then would fade away after 5-10 seconds.
Any help is appreciated.
  • 10,594 Answers
Its Normal operation of Onscreen Display.
Posted on Jun 03, 2008
  • edward_thorn Nov 02, 2014
    Its normal operation is to fade away after a short period.
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
This gray box won't go away on my uncle's TV. It says "Video 5 Cable Box" and appears at the upper left-hand corner and won't go away. It has been there for a few days. It's a first. The TV has...
hello my name is rico, you have bad main board, and it needs to replace it, for the square box to go away. if you need more help, call me anytime. 602-810-7149.
Jan 07, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Unstable signal on a SONY KDF-50E2000 08760591
Can you please explain what you mean by an unstable signal? Without details, the problem can be anything from a weak signal being presented to the tuner to a defective tuner to poor signal processing later on. Also, check the picture and sound using different inputs to the set. If hte problem is the same regardless of hte input signal, that tells us that the problem is in the video signal processing circuitry. Also, place a menu on the screen. Is the instability present with the menu display?
Thanks,
Dan
Nov 04, 2009 | Sony KDF-50E2000 50" HDTV
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The Video display stays on the TV
If it is Sony TV then press " i " or Display button on TV remote and on-screen display will disappear.
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Playstation 3 Does not display on TV using HDMI or regular video
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Mar 14, 2017 | Sony Playstation 3 (PS3) Console
SONY KDL 40 X3000 - Sound but no picture
Does it do this with other input devices? Sounds like a electrical surge.
Jun 18, 2017 | Sony KDF-E55A20 55 in. LCD Television
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Video Number Display
This is normal if you dont have a picture on-screen.
if you do have video:
try pressing the "display" button.
Jul 21, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Video Label
There's a "Display" button on your remote.  Push it.
Mar 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-E60A20 60 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
