Lost manual on MP 810 printer. How does one replace the ink and how does one access the cartridges. . .HELP!
  • 667 Answers
Hi yopless..Here is a link to download the manual for your printer. I could tell how to do what you want to do but I believe it is easier for you if see actual pictures while you are trying to do it. You can download maybe all three of the guides. ( Quick start,setup and onscree) just so you have yhem for future reference. If this solves your problem PLEASE rate as fixed. If you need more help just add a comment and I'll be glad to assist you further. Thanks and have a nice day.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13799
Jeff
Posted on May 01, 2008
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
Oct 09, 2011 | Dell 810 All-In-One InkJet Printer
How do I install ink in MP 210?
Open the cover of your printer and wait the cartridge are in the center. When the cartridge go to the center that's the time you remove the cartridge. To remove the cartridge just push the cartridge downward until it clicks into place. To replace the cartridge just push upward until it clicks into place. Then close the cover and try to print.
Jun 03, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Canon pixma mp 810
Still just an ink error, you can't refill Canon inks without either replacing the chip or resetting the chip. If you are using genuine Canon, you just have a bad cartridge and Canon will replace for 30 days.
Sep 24, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Where if want to replace the ink
Here is the product support of your printer... you can download this manual this will help you to replace the ink cartridge..
use this link...
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm
Jun 24, 2009 | Dell 810 All-In-One InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Error message that blinks E 1 6. Help!
This error indicates replacement of ink cartridge. You can try to reset the printer by turning power off and then switch it on after 20 seconds. If this works, great, else you will have to get new ink cartridge.
The manual for your All In One device is available at the link below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402
Apr 13, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer problems
clean the cartridge head and then reinsert the ink cartridge
May 12, 2008 | Dell 810 All-In-One InkJet Printer
Won't print
I insert the new ink cartridge still it saying ing is low( its original)
Mar 12, 2008 | Dell All-in-One Printer 810 with 2-Year...
Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
