Burner won't shut off - Heating & Cooling
  • 828 Answers
Not enough information
Posted on May 01, 2008
The fryer burners and pilot works fine but when I try to turn it off by the thermostat the fires go down a little but won't cut off, what could cause this
Likely one of two things. The thermostat is stuck on or your gas valve is bad. Identify one of the wires going to the thermostat and disconnect it, if the burners shut off with the thermostat disconnected the problem is the thermostat, otherwise it will be the gas valve. All this assumes the unit is wired correctly and has not been changed. If your burners are not shutting off due to a bad gas valve or thermostat you are at risk to have a fire! Be sure to get this fixed immediately and it is unsafe to operate the fryer until repaired.
Mar 20, 2013 | Frymaster Dean Kitchen Appliances - Others
Bottom burner won't heat up
shut the breaker off to the unit. if the bottom burner is exposed remove the screws at the back of the burner and ease the burner out. there will be a wire connected to each side of the burner. remove both of the wires and test the connections of the buner for resistance with an ohm meter if open you need a new burner if not it could be a control. this is assuming your range is electric not gas
Mar 27, 2012 | Ovens
One of the burners won't turn off.
It is possible that there is a leak on the jet nozzle control system as the gas seems to escape into the burner.
This is not good and you need to take immediate action to rectify the LEAK.
it is important to shut down the connection and use compressed air to test, remove and replace the damaged control unit.
Sep 24, 2011 | Frigidaire FEF336BC Electric Kitchen Range
Ignitor won't shut off gas range
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 25, 2011 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
Burners won`t stay lit.........
There are several possible causes for this. Bad flame sensor, bad thermostat switch, blocked air vent, or bad gas coils.
This website
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Has very good troubleshooting and repair information for all of the possibilities
Feb 02, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
