Question about Whirlpool Calypso GVW9959K Top Load Washer
Water won't stay in washer ...
Need help! Try starting a load of chef whites for work tomorrow, water goes into washer but won't fill and stay. Just runs and runs. What is wrong with it and more importantly can I fix it? (Live in an apt. complex and maintance crew around here is lacking)
Don't see my washer listed below, it is a : 9.8 amp, 120 volt, 7 cycle, 2 speed combo, xtra large commercial quality washer with a porcelain basket. Model #: LXR7244PQ4 Serial #: CT25300027
  • jerryp777
    jerryp777 May 11, 2008
    Same problem: Almost brand new top load washer Whirlpool model LXR7244PQ4: Sometimes it will not agitate after it is suppose to fill it with water and if it does then during the rinse cycle, the water is draining non stop and because it doesnt have enough water, it does not agitate. I tried to pull up the drain hose because it is long and it was all in the drain pipe which is high, following the logic that it is causing a vacuum lock and just keeps draining. Any other solutions?
  • Anonymous Mar 05, 2009
    I HAVE THE SAME PROBLEM RIGHT NOW WITH MY WASHER... SUCKS
  • 487 Answers
Either the pump is broken or the drainhose is lose or too low.
There is also in this machine something called a drain protector. This might be faulty too and i think that would be the cheapest to see about that first
LINK for the water drain including all parts
LINK for all machine parts motor and pump
Posted on May 01, 2008
  • eric bosman
    eric bosman May 02, 2008
    Make also sure there is a little wiggle room for your drain hose in the drain pipe. If you close this of completely you can create a vacuum which strangely enough Syfons the water out of your machine.
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Cold water won"t fill
check the filter... make sure the line is not kinked...
Aug 08, 2012 | Magic Chef CAV2000 Top Load Washer
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer filled up with water but not won't drain spin and is making a funny noise . It's an older magic chef.
The most common issue would be the coupler for the motor transmission. It is a rubber coupling and when it goes bad it makes a grinding, or whirring noise and the machine won't spin or wash. You need to remove the cabinet and look directly under the tub where the motor and tranny connect. This is a reletivly easy and cheap fix. Just google how to replace motor coupling on a top load washer and you may also include your make and model for more direct instructions.
Jun 23, 2011 | Washing Machines
Washer fills w/ water, but will not stop filling. Therefore it never goes into the agitation cycle. Any help greatly appreciated!
Level control valve is bad or line came off it or a hole in line. But it's likely the valve. It could be that you can adjust it and it will work at one level only. it has a screw where you can do that. Just take the panel off and you will see what I mean.
Ken
Sep 23, 2009 | Magic Chef CAV2000AWW Top Load Washer
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
The water wont shut off
Hi, It sounds like the mixer inlet valve has gone bad.
Did you try and shut the power off to the waser first with no results?
Please let me know so I can assist you.
Thanks
Vic
May 27, 2009 | Kenmore 24032\24036 Top Load Washer
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer won't fill
??????? sounds like perhaps you got your 2 hoses reversed when changing the pump assy
Apr 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
613 people viewed this question
Dan Webster
Dan Webster
Sal De
