Question about Tamron 75-300mm f/4.0-5.6 LD Lens for Minolta Maxxum
Attaching it to a Canon EOS 400D REBEL XTI
Is there a trick to attaching the telephoto lens? Is there an adapter or something that needs to be taken off the lens to make it fit the Canon camera? I can't match up the interface to make it work
...First time with a real camera :-)
  • Badoperator May 01, 2008
    This is the package I was sold from FotoConnection. I guess I won't be doing any more business with them.
Totally different lens mounts, you might be able to get an adapter ring, but it wont function amazingly. Honestly, you're better off just selling this lens and buying a Canon 70-300 instead.
Posted on May 01, 2008
Which lens fit nikon d5001
To the best of my knowledge, most, if not all, Sigma lenses fit most cameras that use interchangeable lenses with the appropriate adapter. As I recall, Sigma uses a bayonet mount and adapters are available for many name brand cameras. For example, I have a Nikon and my Sigma 600mm came with an adapter for a Canon. All I had to do was order a Nikon adapter. If you're not sure, you might want to check with a local camera store to confirm which adapter you need.
Jun 17, 2014 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
How do i attach the my zeikos 52mm HD Dslr MC AF 2x telephoto lens to my nikon d90?
You don't. The Zeikos attaches to the front of lens with a 52mm filter thread, which then attaches to the D90. If you have the 18-55mm lens, for example, this will fit onto the front of that lens, effectively converting it to a 36-110mm lens. If you have the 18-105mm lens, this won't fit onto it.
This device is really intended for use with cameras that don't have interchangeable lenses. With your D90, you're much better off using another lens instead of putting this onto the front of another lens.
Feb 13, 2012 | Zeikos ZE2X52B 52mm 2X Telephoto Lens
I have a vivitar telephoto lens for the camera, but not sure how to mount the lens. If I take the outer ring off, I dont know if the lens that came with the camera is suppose to also unscrew, or if there...
None of these Canon Powershot cameras have a lens which will remove.
The ring is only for a special kind of add on lens for either wide angle or telephoto, which will only fit this camera or possibly a few other models.
Never try to unscrew the lens, you will ruin the lens permanently.
Oct 17, 2009 | Canon PowerShot A540 Digital Camera
I was given a sigma mirror-telephoto lens (600mm) It says right on it that it is for a Cannon. I have Cannon Rebel xt and cant figure out how to attach it. Does it work with a Rebel? And if so how? Do I...
You need a T-mount ($30) for a Canon on E-bay or a big camera store. There is NO connections to the camera body, so you have to turn off auto focus and go to "Auto" mode (the shutter speed will change) as the lens is fixed at F8. The mirrors give very little depth of field, 4 or 5 feet when far away but everything in back is a blur of circles. At F8 the shutter speed can go slow and at 600mm you may need a tripod.
Jul 18, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma 120-300mm f/2.8 EX HSM APO adapted to digital Canon
Hi The 120-300 f2.8 is a full frame lens so it works on all canons with a eos fitting
Jul 14, 2009 | Sigma Zoom Telephoto 120-300mm f/2.8 EX...
Nikon d40, t-mount adapter, showing error no lens attached.
You'll need to switch to M (Manual) mode. You won't get any metering through the lens, nor will you get any autofocus.
Jun 11, 2009 | Quantaray 500mm/1000mm Preset Telephoto...
Instuctions for opteka 650-1300 lens for use on konica minolta
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Jan 18, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Lens Adaptor
The best source for the lens adapter is eBay.
Jan 08, 2009 | Kodak LENS ADAPTER 49 TO 55MM Lens...
I have an SP 510 UZ digital camera. I have just bought a new telephoto lense, but I can't seem to get the existing lense off the cammera. Help!
Hey john42hockey,
The lens on this camera is not removable. What you need to attach the telephoto lens to your camera is to get a 43-55mm Step-Up Ring, and a CLA-1 lens adapter tube. You should first attach the lens adapter tube to the camera, and then screw the step up ring into the tube and then screw the telephoto lens into step up ring. I have included a link to the manufacturer where you can purchase both the step up ring, and the lens adapter tube incase you need these. I hope this helps!
https://emporium.olympus.com/innards/empProdDetails.asp?sku=200558-410
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Cameras
Tamron 75-300mm f/4.0-5.6 LD Lens for Minolta Maxxum Logo
189 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
