Question about Kitchen Ranges
Stove how can i clean inside the double glass on my oven door
  • 2 more comments
  • Anonymous Jan 19, 2009
    Liquid became trapped between glass on oven door. can the door be disassembled safely without compromising it function?
  • sbrown13 Jan 24, 2009
    we have the same problem. It is definitely a design flaw. There has to be some way to get between glass and clean it
  • Anonymous Feb 22, 2009
    Same thing...every time we use the self-clean option! Our kitchen looks clean all with the exception of these white streaks on the inside of our oven. I'm going to follow the advice of the person whose door unfortunatley shattered. Wish us luck!
  • Carwen K
    Carwen K Jan 25, 2014
    I have the GE JSP46W0D2WW as of July 2003 and none of these posts applied to me. I figured out how to disassemble the door and have now cleaned both the removable glass panel and the front face of the window in the oven door itself. Obviously whoever designed this range did not understand that condensate from the vents will drip onto the inner face of the front glass panel and the oven door. He also did not know that the white plastic handle and its surround cannot be cleaned. Also that these would become scorched over time in some places due to heat exhaust from the oven. I could go on... 1. Anyway, first remove the door. This is very easy and is described in your owner's manual. You simply open the door a few inches - the hinges will come to a stop point. Grasp either side of the door and pull upward evenly. The door will slide out of the hinge bracket. 2. Lay the door flat, glass side down, on a tabletop that you have protected with thick cardboard or an old rug. 3. Remove the four screws from tabs along the bottom edge of the door.l 4. On each side of the door, remove the two widely spaced screws (not the two closely spaced screws at the top of the side edge). 5. Carefully lift off the inner oven door. Don't forget to clean the outside window. 6. Now you can get at all the grunge that is otherwise inaccessible, including the awful crud along the bottom edge of the door. I was not able to remove the glass panel from its track at the bottom edge, but if you work from one side to the other a few times with degreaser, old toothbrushes, and toothpicks, you can root out most of what has collected there. When you put the door back together, first align the tabs along the bottom edge of the door, then loosely replace the screws. Do the same with the screws in the side edges.Tighten all screws. Replacing the door is even easier than removing it. Make sure each hinge bracket is angled out to its natural stop point - as if you had the oven door partly open. Align the slots in the door with the hinge brackets - you may want to have a helper eyeball this. Push the door down evenly until it stops. Nothing seems to snap or spring back into place, but the door is secure. I think there is a pressure fit with the brackets. Good luck to you!
We cleaned the inside of our glass door today, it was easy but unfortunately we had a problem. Hopefully this will help you avoid the problem we had which shattered the outside glass on the door.
1) Open the door all the way, but put some support under the door to prevent it from dropping. It helps if you have someone else support the 2 halves of the door.
2) There are 2 screws on the top inside of the door. Carefully loosen both screws. This will detach the front of the door from the back and allow you to clean it. BUT, this is important: Do not allow the inside of the door the swing back toward the closed position as this will cause the glass to shatter.
3) Open the 2 halves of the door only enough to get your hand in and clean the glass. Avoid moving the doors while cleaning and avoid excessive pressure on the clean when cleaning.
4) Once you finished the cleaning carefully place the doors back together and tighten the screws.
Posted on Jan 05, 2009
  • Sagbay32 Apr 22, 2011
    Very good advice on not letting the oven door close while cleaning it. I placed a large cardboard box on the door to prevent it from slamming closed. I also placed a smaller cardboard box under the door to prevent the door face and glass from falling before loosening the 2 top screws (that also hold the handle). Take care not to move the handle around on the front of the door while trying to re-attach the handle as it will scratch the front of the door.
Good luck to you!
Posted on Jan 25, 2014
All I know is you would need to be careful because isn't there insulation in the side of the door?
Posted on Aug 14, 2010
I guess we need to remove one of the two pieces of glass of the door to clean in between.  But how to remove and get back in place.
Posted on Jan 15, 2009
2 Suggested Answers
  • 50 Answers
SOURCE: Clean Oven Door Glass
It is much more complicated than that. There are usually more screws once you take out the first 5. There are a total of 3 panes of glass inside the door. If you are very careful to note how the door comes apart once you've removed the screws, then you will be able to do this yourself. Just be aware that this is going to be more complicated than it looks. Lay the door on your counter or floor with the outside of the door up. Take out all the screws around the outer egde of the door. Lift by the handle and turn the top half of the door over so the handle side is on your counter. You will see 2 panes of glass held by the same bracket on each side. You only need to take one of the brackets off and remove both pieces of glass. Now you can clean the inner most piece of glass. Then clean the 2 you removed and put them back. Now reasssemble the door in the reverse steps. Make sure that all insulation and seals are back in place.
Posted on Jul 22, 2008
How do I clean inside double panes glass in oven
the door will have to removed and taken apart. Different stove ovens doors come apart differently. be careful and lay the door down on a sturdy surface when taking the door apart.
Oct 04, 2014 | Ovens
Kenmore stove
Condensation streaks on an oven door window can be between multiple glass panels such that it is necessary to disassemble the door to clean.
Oct 30, 2013 | Kenmore Kitchen Ranges
I have cleaned my oven in a house I have just moved into. but I cannot get to the double glass in the door, how do I clean in the middle of both peaces of glass. There are no visable screws or clips like...
this is all i could find out...
How to clean between the glass panes on an oven door:
  1. Remove the access panel or drawer below the oven door.
  2. Attach a moistened glass cleaning wipe to a piece of coat hanger wire.
  3. Slide the wire and cleaning wipe up through the slots in the bottom of the oven door.
More items...
How to Clean Inside the Glass on an Oven Door ' Today's Homeowner..
or go to this link..
how to clean double glass oven door Google Search
Oct 27, 2017 | Caple C203 Electric Single Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Kitchen Ranges Logo
1,458 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
