Question about Radio Shack Pro-95 Handheld Scanner
Pro-95 stopped scanning
I tried using Don Starr's scanner utility to upload some new frequencies and when I tried using the scanner after the process it would not scan. I even tried resetting it but with no luck. Can someone please help me? Thanks
  • mickyd52 May 01, 2008
    tried this three times and could not get it to scan. hope we can figure this one out. Thanks for trying.
  • 3,037 Answers
Try reloading the frequencies or deleting them altogether and see if it starts working.
Please let me know how this goes and we can go from there to fix this problem.
thanks
Posted on May 01, 2008
  • Benjamin Patri
    Benjamin Patri May 01, 2008
    What did you try exactly?
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    President:
  • 2,712 Answers
There might have been a problem when uploading new frequencies with the utility, and all frequencies are erased. Unless there are some frequencies on the scanner, it will not scan.
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
It could also be that something might have fried inside. If you are unsuccessful trying to program new frequencies, I recommend you take the scanner back to Radio Shack and get it sorted out by a pro.
Hope that helps...
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
    Genius:
  • 1,447 Answers
Try to turn off unit and remove battery pack, then reinstall it after 10 mins and while its off press scan button for 5 seconds and turn it back on. it should automatically go to scan mode on WX
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
How do you program a radio shack to the 700mhz trunking chanels
You will probably have to use a '3rd party' SOFTWARE package. Mr. Donn Starr has written software for most of the GRE / Radio Shack scanners, and using his software will usually allow you to enter 700MHz frequencies. You will need the USB Scanner programming cable and software from Radio Shack, then search online for a link to get Don Starr's software. You might be able to try it out for free for a little while, but it is really worth the $30 for how easy it makes it to program your scanner once you get the doggone Radio Shack USB scanner programming cable configured to work with your computer. Let me know if you have more questions.
Mar 11, 2011 | Radio Shack Pro-2096 Base Scanner
Is there software for the pro 96 to monitar edacs
This scanner only monitors 2 of the 3 types of trunking systems. There is no digital voice inversion. There is an AGC control for the digital voice to try either way DG (on) or Dg (off) There is software you can buy to program the PRO96 from Don Starr. There are two Yahoo GrOUPS you can join to discuss this radio, in addition to forums on RadioReference DOT com.
73's
Jun 19, 2010 | Radio Shack Pro-96 Scanner
All channels locked out
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct.
If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency ###.#### then press "ENTER". Press "PGM"key again and enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies.
When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope this helps. I have owned the pro 95 for maybe 6 or 7 years and after doing a little programming yesterday the thing is much more to my liking. It scanns quicker and scans the channels I wish to listen to.
Jun 26, 2009 | Radio Shack Pro-95 Handheld Scanner
All channels locked on my radio shack pro-95 scanner
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
Make sure you are entering your frequencies in empty channels unless you want to over write one that you don't want to use any longer. Press "PGM" until you get to an empty channel.
Jun 08, 2009 | Radio Shack Pro-95 Handheld Scanner
Scanner not working
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Feb 08, 2008 | Radio Shack Pro-96 Scanner
I have a pro 96 scanner that i just cant seem to program. how can i do it?
Call your local Radio Shack. They can either program it for you or suggest someone who can.
Dec 19, 2007 | Radio Shack Pro-96 Scanner
Programming
Go to Don Starr software link at:
http://starrsoft.com/software/win96/default.asp
The best $30 you will spend to make the Pro 96 sing for you.
Also use:
http://www.radioreference.com/
This site has all you need to get going and a direct download of frequencies and talk groups for trunked systems...
Cheers,,,Tom M sends
Oct 04, 2007 | Radio Shack Pro-96 Scanner
Radio Shack Pro-95 Handheld Scanner Logo
69 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
