Question about Matsonic MS8137C Motherboard
Mother board post
Comment by Theocanj, posted on Apr 30, 2008The CMOS battery is the round battery on the mother board, correct? If so, I replaced it and still nothing. I guess I should try replacing the power supply now as well and perhaps both of them being new is the answer?
  • 385 Answers
Yes, if replacing the cmos battery does not solve it, then maybe the power supply also is faulty.
Thanks,
Lolita
Posted on May 03, 2008
Hi, i replaced my motherboard battery in my compaq evo n620c and it still does the same thing as before.
HI there
could you please re post below where it says add a comment
telling us what the problem is with your laptop
what does it do both before and after your replaced the mother board battery
which i am assuming that it is the cmos battery
many thanks
Jul 07, 2011 | Toshiba Computers & Internet
MOTHERBOARD PROBLEM HELP....THIS IS MY 3RD POST ABOUT THE
You have a corrupted bios file or files. This is what the checksum means. You need to download the correct bios onto a floppy disk. That floppy disk needs to formatted as a system / startup disk BEFORE you copy the bios files to it. Then put the floppy into your floppy drive, turn the pc on and try to get into the bios screens. If the keyboard error is preventing this, go to the mainboard manufacturers website and check the correct manual for the board looking for the procedure to recover from a bios failure. If this board if no older then 5 yrs, it should have this feature. Follow the recovery procedure to rewrite your bios. When that is fixed, undertake the bios update procedure. ONLY do this if you fully understand and accept the risks otherwise, take it to your local professional. If your board does not have the recovery feature, replace it !!unless you are able to replace the CMOS chip with one which has the correct bios burnt onto it. As most modern boards have CMOS chips glued and soldered to the board, this may not be an option..If the bios chip is socketed, contact your local computer shop, or the boards manufacturer to request a replacement. Your issues all arise from your bios issues so fix that and all should be well..
Dec 12, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Where to find the cmos battery
Toshiba made it hard to get to this battery. You will have to remove the entire motherboard and it is in the bottom corner, soldered to the board. I just went through this for a friends computer, it was not fun.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If this post has helped you, please help me, and rate this suggestion with the highest FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
May 16, 2009 | Toshiba Satellite P15-S420 Notebook
Re: K8MM-V
hi, check the cmos battery then set the correct values, fsb,clock settings,ect..post again if you need more help. good luck!
Mar 06, 2009 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Where is the CMOS Battery? Acer 2303lci
It is in the middle of the mother board. It looks just like a watch battery.
Feb 07, 2009 | Acer TravelMate 2303LCi Notebook
Dell 8200 won't turn on - power supply is good
Have you put in a CMOS Battery? Hard drive works?Any more information that was not in your first post?
RCF
Sep 06, 2008 | Computers & Internet
Laptop shuts down prox 1 minute into startup.
You can change it by rating his solution as thanks for trying or just denying it.Then rate or accept my solution as fixya.
Apr 04, 2008 | Toshiba Satellite A105 Notebook
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Matsonic MS8137C Motherboard Logo
164 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
