Just bought a new samsung tv and cannot figure out how to connect it to the new tv using the red, white and yellow connectors as there is only one yellow on the tv and that is used for the cable
  • 3 Answers
Put the cable plug somewhere else in the tv and put the colored wire(s) in the tv
Posted on Apr 30, 2008
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
How do I hook up my little DVD player to my tv?? The DVD player only has red, yellow, and white cords,, where to I plug it in at on the back of the tv and which setting.
New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
Aug 21, 2011 | Samsung 50 in. Plasma TV
No tv sound. Dvd works alright. Have hdmi cable from theater sys. to tv. Cannot figure out how connect red,white or yellow cables.
By Visio "55 I'm presuming you mean the Vizio VF550XVT.
First you need an Audio Cable (Red/White RCA Connectors) and with everything turned off connect it to your TV where shown below.
The other end of the cable will then connect to the Aux In 2 of your Samsung HT-Z320 as shown below.
Once connected you can turn your Vizio & Samsung back on.
You then need to use the AUX button on your Samsung Remote Control to Select Aux 2.
And on your Vizio Remote Control follow the Instructions below.
Please leave feedback
Cheers
Andy
May 14, 2011 | Audio Players & Recorders
Trying to connect a new Samsung Bd-C5500 to my old Sony tv. Can't even get the set-up screen to come up on the TV. All we have is a TV, a Cable box and this new Samsung. We bought it because it is...
That depends on the connections your Sony TV has. If it has only the coaxial connector (the cable looks like this: http://www.w-l-t.org/Pix/Coax%20w-F%20connector.jpg), then you'll connect a VCR to that, and then the blu-ray player to the connections on the VCR using the composite cables (yellow, red, white). Switch the VCR to channel "L" or "Line" (usually below channel 2), and it should pass the video through to the television. Of course, if the TV itself has the yellow, white, and red connectors, you should just be able to connect the Blu-ray directly into that.
Also, it may be possible to connect your cable box as an intermediary like I just described with the VCR, depending on your model of cable box.
Oct 28, 2010 | Samsung BDC5500 Player
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
I have no sound from my samsung tv to Samsung HT-TZ315R/XEU i have connected with hdmi and the white and red plugs i have sound from the dvd player but not the tv any suggestions
Make sure the red & white connectors you are using on the TV are actually audio out, and not audio in. If you are using the connectors on the side of the tv (adjacent to the yellow connector), then these are inputs.
If your TV has no audio out connectors, then if you have a European TV, you can use one of the scart connectors with an adaptor.
Also, check the red & white connectors you are using on the home theatre system are inputs. Also check the source is set correctly.
May 16, 2008 | Samsung Televison & Video
Tv-dvd connections
first what model samsung? second if the tv has yellow red white then you need to change the tv to the input you are using. for best picture I would use an s-video cable it will give you superior video images since I don't know what brand dvd player I only say this if you have an output on the dvd player
most important is to make sure the tv is on what input you have plugged in. and dont forget to power up both units.
Apr 27, 2008 | Televison & Video
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
