Question about Malber WD1000 Front Load Washer/Dryer
Using for the first time and won't work
We did everything per your instructions and washer isn't beginning to load water. We did turn on the faucets. Please help!
Thanks! Elana and Lou Kohn
    President:
  • 2,712 Answers
Hello Loulan,
This is a pretty common problem and the solution is quite simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
One cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • Swilin Sampson
    Swilin Sampson Apr 30, 2008
    If this doesn,t work, it could be that the water inlet valve is faulty and will need replacing.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
  • Malber Master
  • 19,396 Answers
If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • Posted on Apr 30, 2008
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    My figidaire pauses after two or three minuets
    Hello.
    what you need to do to solve the problem of the washer is to troubleshoot below are step by step solution on how to solve the problem.
    If your washing machine is out of whack, check for these easy fixes
    before you spend money and time on a repairman.
    1 Make sure the cord is plugged in and that the breaker hasn't tripped.
    2 Reset the overload switch - according to the manufacturer's directions - if the machine won't turn on but the breaker hasn't tripped. (Make sure you take some of the clothes out before you run it again or you'll have the same problem.)
    3 Check the hot water faucet if the water isn't warm. Also clean the filter screens and make sure that your hot-water heater isn't out of hot water.
    4 Make sure the faucets are on, the filters are clean and that the hoses aren't kinked if the washer is filling too slowly.
    5 Clear any obstructions in the hose if the clothes are too wet at the end of a cycle. Also, be sure the washer is spinning; if it isn't, remove some of the clothes and redistribute the load. Reset the overload switch. Tighten the drive belt if this doesn't fix the problem.
    6 Check the hoses for damage if you are seeing water leaks on the floor.
    7 Put a nylon stocking on your hand and feel around the inside of the washer if you are finding snagged or torn clothing. Sand rough spots with fine sandpaper.
    Thanks.
    Nov 13, 2011 | Frigidaire Washing Machines
    Error code e01 f08
    Knowed as F8 E1 error code...
    This code indicates there maybe a problem with the water supply to the washer. Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
    NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
    Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; you can find them by entering your model number in the search tool below.
    Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
    Are you using HE High Efficiency detergent? Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
    Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
    To remove the error display, press Power once. Then press Power again to restart the washer. If pressing Power does not work:
    Unplug the washer or disconnect the power for one minute.
    Plug in the washer or reconnect the power.
    Re-select the cycle and press Start.
    NOTES:
    * On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
    * If the error remains on the display, and all of the other conditions above have been checked, call for service.
    Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using Fixya, and have a nice day.
    Oct 26, 2011 | Whirlpool WFW94HEX Washer
    My washer is flashing LF
    LF error code indicates that there is a water supply problem.
    Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
    NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not properly operate with only one incoming source of water.
    Are the water inlet hoses kinked? Straighten the water inlet hoses.
    Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
    Is the drain hose extending more than 8" (20.3 cm) into the drainpipe? The drain hose may be too far inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shaped drain hose form as described in the Installation Instructions will provide the appropriate length of drain hose in the drainpipe or laundry tub.
    Check it and keep us updated. remeber to rating this free answer and leave some testimonila comment.
    Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Error code H F
    Display shows F20 or FH - Front-load washer...
    This error code indicates a water supply problem. Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
    Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
    Are you using flood-preventing inlet hoses that can shut off the water to the washer?
    These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
    To remove the error display, press Pause/Off or Pause/Cancel twice.
    If Pause/Off or Pause/Cancel does not work:
    NOTES:
    Hope this helps to solve it; remember to rate and comment this free answer.
    Jun 27, 2011 | Maytag MAH8700A Front Load Washer
    Hi, I'm assuming my line is frozen. It says H F, and no water is coming out. The laundry room doesn't have any heat going to it. I'm trying to warm up the room to see if I can get it going. Please...
    Jan 01, 2011 | Washing Machines
    My Whirlpool front load washer has an error code of F-20 and will not finish the wash cycle. What is wrong and how do I correct it?
    drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
    fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
    helogo.jpg See also: Why HE High Efficiency detergent is required.
    To remove the error display, press Pause/Cancel twice.
    hcz_003_web_env1.gif If Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start.
    NOTES:
    • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
    • If the error remains on the display, and all of the other conditions above have been checked, call for service.
    NOTE:The above article dircty from whirlpool customer help site.
    Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    The code is f 20
    Apr 01, 2010 | Whirlpool GHW9100L Front Load Washer
    Whirlpool duet hf error
    NOTES:
    Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Open Questions:
    See all Malber WD1000 Front Load Washer/Dryer Questions
    Malber WD1000 Front Load Washer/Dryer Logo
    Top Malber Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    ashburton
    Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
