I have a 80g external hard drive can't access any files any help?
    Problem Solver:
  • 11 Answers
Does the drive turn on or spin up?
Does your computer recognize the drive in "Device Manager" if using windows?
What type of drive is it?
there are many situations in which your drive could be in, ANY more information would be helpful
-MM
Posted on May 01, 2008
I can't access my wd external hard disk (passport )through (my computer) i can see it using windows disk management as unallocated partition...when right clicking..no options are active but properties
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
May 11, 2011 | Western Digital Passport WDXML800UE...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
Can't access Ion Drive
You have to check also Disk Management while your HD is connected to the your computer.
First, if you can detect the HD in your Device Manager but not under the Disk Management, then the IOGEAR Tech Support is could be correct.
If that's the case, you need to contact IOGEAR and ask them to send you a USB Y-Cable. That Y-Cable is FREE. IOGEAR will just ask for your billing address, and they can send you one for free.
That Y-Cable has two type-A USB and one mini-B USB ports. The two type-A should be connected to the computer, and the other end to your HD. Having two USB connected to your computer, that should be enough for the HD to get power from the two USB ports.
If that did not help, I would suggest to connect your HD into different computer to see if you can detect it.
If you do detect it, back up all the files, reformat your HD, change the drive letter, and then retrieve all the files back.
Thank you and good luck!
Feb 18, 2010 | IOGear 2.5" Hi-Speed USB 2.0 ION Drive II...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
80G external drive claims to have only 14G free when empty
you will have to format your external drive again, using NTFS file system, and also check & connect your drive with some other pc's....
good luck
shafky
Jun 26, 2009 | Computers & Internet
Ps3 sata data retrieval???
put the sata drive in the new ps3, then offload the information onto an external discdrive through the settings menu. it is the back up option. then put the new drive back into the ps3, reconect the external drive, and go to settings, and i beleive it is called something like restore, and you can retreive the saved data from the external drive and put it on the new ps3 drive. hope that helped. please tell me if it did or not.
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Connected IDE Drive does not mount on desktop
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Mar 18, 2009 | Apricorn DriveWire IDE/PATA/SATA to USB...
Hard drive for acer laptop 525 TE travelmate
You can use an external hard drive with an USB hard drive case and and connect it to your USB port
Jul 07, 2008 | Acer TravelMate 2300 Notebook
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
*Note*
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | HP Compaq d530S PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
