Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Need a lil help here!
Ok i have a 30gb zune it has worked fine for 4 months and all the sudden i went to turn it on after i had charged is and it turned on however it wont play any music, movies anything everytime i press play it say error can not fine file. So what i did was resync aeverything back to the zune and still it wont work
  • jay00 May 09, 2008
    ok my 30gb zune was fine untill it started turning off and on itself every lil while, it still shows the normal screen and the backlight but it just wont respond to any button i press... at all! on top, when i conect it to the pc it wont apear on the zune program i instaled for it :s what can i do???
  • Midnight98 May 27, 2008
    one night my zune was dead so i went to charge it. I plugged in the USB cable. I woke up the next morning to find out that my zune did not charge so i plugged the zune in again and still it would not charge so then i tryed to turn the zune on. it would not turn on either. can sombody please help
    thanks,
    ADAM
  • 8,596 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 06, 2008
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Apr 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB won't charge in car.
Some auto usb cables aren't compatable with Zune device.
Mar 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune freezes after charging
ok well for this you will have to go to the zune website and go to support and send a repair request as of last night all 30gb zunes including mine went blank and would not work so microsoft should have and answer soon.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
30GB Zune Froze
all of the zunes 30gb in the world went dead last night go to zune support.com and request a repair they will be helping you soon .
Zune screen is black and won't charge
you could have a bad charging cord and also you can try to turn the hold button on and off that sometimes works
Nov 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Help My Zune Turns On But Blank Screen
Hi guys,
I wanted to start a sticky thread to give you a place to discuss the issue with the Zune 30's freezing. Rather than hijacking other threads or creating tons of repeat threads, please post here if you want to discuss.
I will post any information I have in this thread as it becomes available. You can also monitor http://www.zune.net/en-US/support/default.htm for updates on the issue.
I can assure you that the team is working to understand and resolve the issue as soon as possible. My apologies to all of those that are affected by the problem. Thank you for your patience!
-Matt
[Update - 2:20pm PST]
Hi guys,
I just got an update from the team that I want to share with you. Great news! It looks like this issue will resolve itself over the next 24 hours. Please read the response below. Thank you all for your extreme patience with this!
-Matt
Early this morning we were alerted by our customers that there was a widespread issue affecting our 2006 model Zune 30GB devices (a large number of which are still actively being used). The technical team jumped on the problem immediately and isolated the issue: a bug in the internal clock driver related to the way the device handles a leap year. The issue should be resolved over the next 24 hours as the time change moves to January 1, 2009. We expect the internal clock on the Zune 30GB devices will automatically reset tomorrow (noon, GMT). By tomorrow you should allow the battery to fully run out of power before the unit can restart successfully then simply ensure that your device is recharged, then turn it back on. If you’re a Zune Pass subscriber, you may need to sync your device with your PC to refresh the rights to the subscription content you have downloaded to your device.
Customers can continue to stay informed via the support page on zune.net (zune.net/support).
We know this has been a big inconvenience to our customers and we are sorry for that, and want to thank them for their patience.
Q: Why is this issue isolated to the Zune 30 device?
It is a bug in a driver for a part that is only used in the Zune 30 device.
Q: What fixes or patches are you putting in place to resolve this situation?
This situation should remedy itself over the next 24 hours as the time flips to January 1st.
Q: What’s the timeline on a fix?
The issue Zune 30GB customers are experiencing today will self resolve as time changes to January 1.
Q: Why did this occur at precisely 12:01 a.m. on December 31, 2008?
There is a bug in the internal clock driver causing the 30GB device to improperly handle the last day of a leap year.
Q: What is Zune doing to fix this issue?
The issue should resolve itself.
Q: Are you sure that this won’t happen to all 80, 120 or other flash devices?
This issue is related to a part that is only used in Zune 30 devices.
Q: How many 30GB Zune devices are affected? How many Zune 30GB devices were sold?
All 30GB devices are potentially affected.
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune turns off
i had the same problem
try this it worked for me conet you zune to a charger externaly ie not on the computer
through the mains plug adapter it works fine but when i unplug it go back to flashing on and of
let me know how you get on
Oct 22, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
54 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
