I have a Bosch washer (model Wfk 2401) and I haven't used it in a couple of weeks. I noticed that the washing drum is filling up even though the washer hasn't been used. Any ideas?
  • 487 Answers
The valve( main inlet) is broken. Most likely due to limescale buildup.
you might be able to clean it or just replace it as they are not too expensive
All the parts you need you find HERE
Please rate me as FIXYA if this info resolves your problem
Posted on Apr 30, 2008
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Sep 19, 2007 | Bosch WFK 2401
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
