Snooze my laptop keeps coming back on when i close down the snooze light is switched on how do i turn it off
  • Ronald Tisdale
    Ronald Tisdale May 11, 2010
    I need you to be a little more specific... Tell me exactly what you are trying to do and what you want the PC to do in response.
    Like heres an example "I'm closing my laptop so it will enter sleep mode but the display is staying on"
    I just need a little more specific information and also the brand and model of laptop would be helpful. Thank you.
    Scholar:
  • 33 Answers
If it is a newer laptop (meaning you purchased it at any date since January 28th of 2007) then you are running Windows Vista™, most likely the basic or premium versions. The actual version does not matter, but you might be able to agree or identify your operating system from those titles.
When you close the lid of the Laptop, the computer is being told to execute a command that has already been pre-defined by Microsoft to hibernate or go to standby to conserve power. Or when you open the lid it will not resume unless you press the power button.
These are settings in the computer that you can change, you just have to know how to access their context menu in order to do so.
The easiest way I can explain to do so is this:
1: Press the windows key on your keyboard, or click on the windows icon in the bottom left of the screen (the start menu).
2: Type in "Power Options". The computer will quickly find the power settings for your machine.
3: Notice the plan your unit is currently set to. Underneath the plan name, is a blue lettered option called "Change plan settings". Click to change the settings.
4: Choose "Change advanced power settings" from the middle of the screen.
The menu that appears contains the behaviors of your entire system in relationship to your power settings. In particular, if you would like the computer to turn off when you close the lid, expand the menu called "Power buttons and lid" and change the option from "Sleep" to "Shut Down"
You can always return to this menu and select "Restore plan defaults", so don't be too concerned with accidentally configuring your power options incorrectly.
Hope this helps you set-up your laptop the way you like.
Posted on May 01, 2008
Cant get the laptop screen to come up the snooze button light is on
Try holding the power button down for 5 seconds this will fully turn off the laptop - then try switching it back on. Also try removing the battery then switching it back on, hopefully this will clear the fault.
You could also check the keyboard. If you have a faulty keyboard, it maybe that the key that puts the laptop to sleep is faulty. You may need to disconnect the laptop keybaord and use a USB one - if the fault goes away then the fault is with the laptop keyboard.
Hope this helps.
Leon
Feb 09, 2013 | ASUS Computers & Internet
Nokia 1110 alarm click default snooze to off
when an alarm appears you have two options one is snooze other is off if you select off it wont snooze......... by default snooze will come after 10 mins even if you missed it first time you can off it next time ok.
Oct 21, 2011 | Nokia 1110 Cellular Phone
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
I have a dell inspiron 1521 . All three lock lights are flashing and then the systems shuts down . Turns back on and flashes then shuts back down repeating this process constantly. I have the original...
same problem i slove ... 1st of all remove ram and turn and wait 20 second .. return the ram on by one .... may b one ram has problem .. if same then open ur laptop remove battery cell for 1 min and keep laptop off .. after one min return cell and dont close laptop just check open is work then close .. if not change thek crystal wich is near the winbond ic... near the keyboard conector.. hope it will be okie .. Thanks
Sep 16, 2010 | Dell Inspiron 1521 Laptop
THE INTERIOR LIGHTS TO MY 98 BUICK LASABRE WON'T TURN OFF. I TRIED TO TURN OFF THE CAR BUT THEY STaY ON THEN WHEN I START IT AGAIN. THEY TURN OFF MOMENTARILY THEN COME BACK ON. WHAT SHOULD I DO?
do you not have a switch on dash for them? try turning the switch counterclockwise to turn them off. or you may have a bad switch on the door jam,,look for a plunger swictch on the door jam itself push the plunger in on the doorjam,,if the lights go off, then you'll know the problem! hope this helps!1
Sep 16, 2010 | 1998 Buick LeSabre
When I push the on button after the oven is in "Snooze" mode, the oven starts cooling down instead of heating up . Then when I push the on button again, the screen comes up and says oven ready.
Pushing the Back touch pad will give Snooze option, push it again and the Oven Off comes up. From there you can leave it off to cool down and clean, or push the bottom right pad to turn on,
Jul 16, 2009 | TurboChef TORNADO Electric Oven
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
