SOURCE: error code 37!!!!!!!!!
I had the same problem. The machine was not draining. I drained the water tipped the machine on its face and exposed the pump. As you face the bottom of the pump there is a plastic lever on the left hand side of the pump. Depress the lever and turn the pump assembly counter clocwise to remove. In my machine I found a piece of a toothpick and a bit of cellophane. Enough to stop the pump impellor. Aside from draining the water it took me an hour to figure this out. Next time it will be 5 minutes!
Good Luck
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
SOURCE: Code 37 on Fisher & Paykel Washing machine - water does not pump
Four main things are associated with this error: pump system, including the hoses; wiring; motor control module; and diverter valve. See the attached pages for details.
Attachment: FP_Washer_Smart_Drive_Diagnostics_Error_Code_37.pdf
Good Luck
SOURCE: FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
