Question about Frigidaire ATF6000ES Front Load Washer
Front Loader Frigidaire will not drain model no. LTF530FSO
Washer front loader will not drain. Light is on and door is locked. Agitator moves in both directions during the final spin cycle. I can hear a slight hum noise poss. coming fom the pump. I turned off the power maybe it will reset istself but no luck.
  • Anonymous May 22, 2009
    so if my washer is full of water, can i still disconnect the hose?
    or will all the water drain out on my floor.?
  • Anonymous Mar 16, 2014
    front loader, model ATF6700FS1 . Digital display turns on when washer is off
Check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Posted on May 01, 2008
    Genius:
  • 1,073 Answers
Check to see what is in the pump
Posted on Apr 30, 2008
My Frigidaire front loader washer is making beeping sound and it wouldn't start.
Hello - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Also try to rotate the drum manually (when it is not in use) and see if you notice a bumping sound as well. If you do, then the drum is not balanced and probably the bearing and pulley system behind the drum will need repairing. You may need to reset the unit at the household circuit breaker for a few minutes to create a hard reset within the unit. Then retry. If it proves to be ineffective contact a professional to move forward accurately. Washer may be experiencing an issue with a faulty door lock, timer, pump or control board not communicating correctly.
Nov 25, 2012 | Frigidaire Washing Machines
How do I runa diagnostic on a Frigidaire Model 41744152400
most front loader washers will wash fine all the time, however there is a pin switch on the front that the door strikes when closed make sure the door is closed and locked .
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
How to change the door lock unit on a front end loader fridgedair
disconnect power cord open door remove spring from door seal and peel seal away from panel remove the two screws that hold the door lock inplace reach inside move the switch so you can access the 3 electrical connecters from the switch and reverse the process also check the door strike on the door and keep in mind if the pump is restricted it can't drain the water and it won't spin hope this helps out
Dec 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader
Click on Frigidaire (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
If u are not satisfied with the manual, click on 'thanks for trying', your prob will be back on the website.
Jan 15, 2008 | Frigidaire GLTR1670A Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
602 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
