My Panasonic Camcorder is Stuck in the Pause Mode after using the Remote Control
I have NO IDEA what happened when I used the Remote Control that day. . I haven't had any problems before. My Panasonic is :Panasonic Palmcorder PalmSight Camcorder #PV-L559. Thank You...HELP!!!!! I am Disabled, so I don't have alot of money to fix this Problem...
  • 14 more comments
  • tennmommy May 07, 2008
    To FixYa, I hope it won't be to mcuhbecause of my limited income and my Sears bill having a really high balance on it now. Good Luck and God bless You
    tennmommy
  • tennmommy May 10, 2008
    I took the Remote Control Battery out and pressed all the buttons at the Digital EIS Stzbilization Remote Eye and when I put the battery back in remote Control, the only thing that DID work was the Zoom In & Zoom Out.
    A Tech at the Panasonic Company Told me to do, and it didn't work. Still Stuck In Pause!!!!
    There is No Dew in the unit.
    I have looked everywhere on this unit and I can't find anything that says Reset on it.
    Thanks for trying,but the solution does not solve the problem, but the effort is appreciated
  • tennmommy May 11, 2008
    I agree with you micromaster. getting alot of people giving me things to try to solve the problem. Some I Had already tried and it didn't fix the problem. I appreciate what you have done micromaster and thank you very much. (:) tennmommy
  • tennmommy May 12, 2008
    I did the remove battery comment you sent IrishDruid and it had no effect on camcorder. Someone suggested that I Find the Reset on this camcorder and to have a Phillips Screwdriver and have the power ON when I do the Reset. When I tookout the battery, I saw something that might have something to do with resetting this thing. I took off the battery and I see thie:It says EVR with an arrow pointing to a small long box that has a Phillips screwdriver. Could this be the Camcorder Reset in there when I take this off? This is getting on my LAST NERVE !!! tennmommy
    tried that Jack_Daniels and it didn't work. thank you for the information. tennmommy
    ok IrishDruid I will call the phone number you gave me for Panasonic Help Line. Thanks so much for your time and help. tennmommy
    I have done that and didn't help. There is No Dew in the unit either.
    I have tried pressing the Record Button and It does no good. There is no Dew in the unit. thank you mewms . tennmommy
    Yes I have tried that and still not working. I don't have Dew or any kinda Moisture in my unit. Thank You mewms_14904 tennmommy
    yes I have tried doing that but it won't work. There is no indication of Dew in the unit. thanks tennmommy
    Tried that too.Didn't work. there is nothing in my unt that says there is Dew in my unit
  • tennmommy May 15, 2008
    Hi Best: I can't open the unit. I wouldn't have a clue as to what to look for. I am going to call the Panasonic Help Line and see if I should send unit to them and if they find the problem, how much would it cost to fix it.I can't afford alot by living on Disability check.
    Hi Micro, I don't know how much it would cost to send unit to Stuart,Fl. That is the nearest place to send it to try to find out what is going on. I am going to call the Panasonic Help Line that I have. Maybe they could answer questions or perhaps say the unit is too old to try to fix it. I got this on July 11,1998. Thank You Micro tennmommy
    Brigadier General:
  • 3,614 Answers
Is it better to put the unit on repair, abd not making the unit into trouble,, is it better to have someone who is better and able to do the things..
Thank you
Posted on May 11, 2008
    Master:
  • 377 Answers
Try to remove first the battery of the unit, to reset it & put back into normal operational settings..
Posted on May 07, 2008
    Genius:
  • 1,027 Answers
Have you tried pressing the record button on the unit and not the remote to un-pause the function?
Does your unit indicate any Dew in the unit?
  • 975 Answers
Lets try this , check the unit and find something that will say RESET , You gonna need like a jewelry type screwdriver to insert it in , you are gonna do this while the camcorder is on , once you do this , turn camcorder off and on again , hope its fix ,
AJ
    President:
  • 2,712 Answers
Try switching the device off, remove battery and/or wall charger and wait for an hour. Put in your battery or wall charger and see if the issue recurrs..
Let me know how it goes..
Cheers!
IrishDruid
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Hope that helps!
    If your issue is
    not resolved, please do not assign a rating just yet. Please post back as
    to what steps you took, results, etc, and I will try to assist you further as
    best I can. I am here at your service.
    P.S. - You can rate a solution with one of four
    ratings as explained under (remember that at times a bit of to and fro dialogue
    may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated.
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    Thank you for using FIXYA!
    IrishDruid
  • Swilin Sampson
    You can also try calling Panasonic help line at 1-800-211-7262
  • Swilin Sampson
    Swilin Sampson May 10, 2008
    Remove the battery from the camcorder, not the remote. If you have plugged the camcorder into a wall socket, unplug it from there, wait about 10 minutes and then power on the camcorder again. It should work.
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    Well, generally, removing ALL power source to the camera (like battery or adapter, if you've plugged it directly to the wall,) should turn the camera off completely. Once the camera is completely shut down, try powering it on and see if it works.
    I dont recommend poking around the EVR thing if you are not sure what you are doing.
    The only other suggestion I can give if none of the solutions here seem to work, is to take it to a local electronics/camera store and see if they can sort it for you. I do not think they will charge you for this, unless there is some other internal device that needs fixing..
    Sergeant:
    Champion:
  • 304 Answers
Kindly please standby, & i'll post back again the solution..
& please provide add info..
Thank you
  • Elizabeth Krijt
    Elizabeth Krijt May 07, 2008
    Try to push the button on the camcorder instead using the remote control.. & try to remove the battery and put it back again to reset the unit..
  • 3,037 Answers
Have you tried removing the batteries yet for 10 minutes?
Please let me know if this works, thanks
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Don't worry, I don't think it will cost anything, just follow my advice and let me know if it starts working again, if not, I can give you other options to try. good luck
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, my solution needs to be rated.
    Otherwise, let me know if you have further questions and I would be more than happy to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 10, 2008
    you took the battery out of the remote but not the device?
    Leave it out for 10 min.
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    the dew may not be actual due but rather moisture, taking a hair dryer to it at a lower setting may not be a bad thing if it is kept in a humid or damp area
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    alright, no dew, the only other option is opening it and checking the internal components
  • Benjamin Patri
    Benjamin Patri May 15, 2008
    you will probably be better off getting a new one rather than sending it in. If you know a guy who likes working with electronics, have him check it out but it will be better to buy a new one rather than pay for them to fix it. I'd bet that they will charge you about $50 or even more but you should just find one for under $200 instead. Let me know if you need anything else, thanks.
    you can always call and see what they may charge but I wouldn't send it in if I were you.
  • Benjamin Patri
    If its that old, then definitely not worth fixing
Panasonic MY143 repair
or u can purchase the 2 cap 0.8uF 275v or 01uF275V will solve the issue.
Apr 13, 2012 | Panasonic Dryers
I have a Panasonic DVD/VCR TV. The remote control works intermittently. Sometimes I can control the volume and DVD/VCR using the remote and sometimes the TV does not respond to the remote. I spoke with...
Do you still have the instruction booklet for the Tv? Find the remote codes and try re-programming the remote. If this still happens try programming an after market universal remote. Hope this helps.
Sep 12, 2009 | Panasonic Televison & Video
Connect my Quasar VHS palmcorder model # VM-L152 to my macbook
get a new camcorder/palmcorder, because of this POS i am now doomed to retape my entire spanish project over again, which i travelled well over 300 miles for
Apr 25, 2009 | Quasar VM-L450 Camcorder
Drivers
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder and ask them for the correct connection procedures to use the palmcorder with your computer. I Hope this information helps you with your palmcorder problem.
Apr 10, 2009 | Quasar VM-D51 Camcorder
My palmcorder keeps saying dew detector
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder. Tell them the problem you are having with dew dector and ask the for assistance. I Hope this information helps you with your palmcorder problem.
Mar 21, 2009 | Quasar VM-D51 Camcorder
Panasonic DVD Palmcorder (VDR-D100) 1.5 yrs old will not power up
Nope men... I have Just the same problem... I have a VDR-D105 and suddenly doesn't turn on... i was recording with a full charged battery and suddenly just turn off... forever :S
Jun 04, 2008 | Panasonic VDR-D100 DVD Camcorder
Palmcorder won't turn on
the cameras internal power supply or pcb has a fault so i recomend you have it checked out by a panasonic technician.
Apr 06, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Computers & Internet Logo
383 people viewed this question
David Payne
David Payne
