I HAVE A GE WASHER MODEL # WVSR1060A0WW WHEN IT FILLS WITH WATER IT WILL NOT GO INTO WASH OR RINSE CYCLE. IT JUST KEEPS ADDING WATER TO FLOOD THE FLOOR.
  • flomom May 01, 2008
    OK , I SHUT OFF THE POWER AND THE WATER STOPPED. I THEN CHECKED THE SWITCH HOSE. UNHOOKED FROM THE SIDE OF THE TUB. IT IS CLEAN AND JUST TO BE SURE I BLEW INTO IT AND THEN THE WASHER QUIT FILLING AND WENT INTO AGITATION MODE.
  • 758 Answers
You will have to check and see if you are getting power down to the motor.
If it will not spin in any cycle it is like the motor or the wiring to the motor
Here is a link to your washer model wvsr1060a0ww.
Hope this helps
Please rate accordingly
Thank you
Computerrep
Posted on Apr 30, 2008
    Genius:
  • 1,073 Answers
How about checking the water pressure hos that connects to the tub it may have a hole or crack in it the hose is 3/8 in in dia. it cnnects to the water level switch
    President:
  • 2,712 Answers
Hello flomom,
There are a couple of things that may be wrong:
  1. It could be that the water fill/inlet valve may be damaged and needs to be replaced.
  2. The water level control switch may have taken a permanent vacation and will need to be replaced.
In my opininon, I would check the water inlet valve first. Hoever, if you are not used o this kind of repairs, I would recommend you get a qualified professional to repair this.
If you like to try a do-it-yourself, then you may need the schematic diagram of parts for your machine.
You may want to invest in floodcontrol to prevent this from happening in the future. And while you’re at it, I suggest replacing the rubber fill hoses on your washer to the steel braided hoses.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    It looks like a problem with the pressure/fill switch. I would recommend you get a qualified technician to do this, if you are unfamiliar with assembly/disassembly of electrical goods.
  • 3,037 Answers
Sounds like the water valve sensor is malfunctioning and needs to be replaced
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 30, 2008
    If
    your washer won't stop filling up with water and overflows the tub,
    check for one of these problems:
    1)
    Turn off the electricity to the washer. If the water *stopped* filling
    when power was disconnected, the problem would usually be in the
    control system of the machine. If the water still continues, then
    the plunger in the water valve is either stuck open or slow to close.
    Try turning the water faucets off an on a few times. This small
    jolt might unstick the water valve. If not, it will need replacing.
    2)
    There could be a problem with the water level switch. Call in a
    repairman if you are unable to check it yourself
    3)
    There is a pressure switch hose that is attached to an air dome.
    This switch tells the washer that there is water in the tub and
    allows the agitator to start.
    - Remove the control panel and you will notice a small hose. See
    if it popped off of the air dome. If it did, secure it with a zip
    tie.
  • Benjamin Patri
    let me know if you need any further help and I would be glad to answer any and all questions that you may have
  • Benjamin Patri
    Benjamin Patri May 01, 2008
    alright, try the machine a few times and see if it starts to work from empty. It most likely is just a sensor that will need to be replaced if the problem continues, if it seems to be working after multiple tries, then leave it be and if it starts acting up, contact me directly on here and I will help you with getting a new sensor, thanks
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
Sep 20, 2014 | GE Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Jul 15, 2008 | GE WDSR2080D Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
