Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door ups and downs
I jsut had to replace my ground sensors and i dont know how that could have interfered with a door that had been working fine for 2 plus years. but after installing the new sensors the door goes up but when you press down the light starts blinking and if you let off the button it stops and starts going back up. if you hold the button down it will go down but you have to hold it to the bottom.
thanks in advance,,
rick
  • 18 Answers
Holding the button down just bypasses the sensors.
Your sensors are not adjusting correctly, or there is a short in the wires.
The back of the machine has a little yellow light, count the flashes and corelate it to the troubleshooting portion of the manual to confirm.
The orange light is a constant, the green sensor needs to be adjusted until you get a solid green light.
Posted on Feb 13, 2009
Garage door gos down and hits the floor and reverses back up. There is also a green light on one sensor and a yellow light on the other sensor. What would be the problem.
I know sometimes if the sun is shining towardso the sensor it will start to go up before hitting the floor but this soundshould like you may have a misaligned sensor or one of them going out but this doesn't explain why it hits the floor first so my answer to you is that the travel distance setting on the motor is not set right it thinks it's hitting something besides the floor the settings for the door travel distance should be on the back of the box that contains the motor I'm sure this is what is causing your problems
Sep 28, 2016 | Chamberlain Powerdrive PD422D 1/2 HP...
My garage door starts going down and stops. it goes back up and will not close. one of the sensors is yellow.
take some toilet paper, or some very light rag and dust the RPM sensor over, under, inbetween and in every spot on that darn thing, and bingo, it will work. Its the plastic ribed piece mounted on the end of the motor under opener cover. If something gets under door as door starts to go down, the RPM`s will slow and thats a warning to stop and go back up. With it being dusty, it can`t sense the RPM`s properly and goes into an alarm every single time. Ugg
Mar 10, 2011 | Chamberlain Powerdrive PD422D 1/2 HP...
My stanley deluxe garage door opener suddently stopped. It only makes tik tik sound. What do i do?
You may look at the safety sensors. Try holding the wall button down. If the door operates with the button held down then it is the sensors. Try to align them to look at each other. If not you are probably looking at either replacing the sensors or the logic board. Thanks BB
Jun 30, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Chewing up Chain Drive
There is most likely a problem with the balance of the door. Release the door from the opener by pulling the red handle and lift the door manually. You should not have to apply more than 20lbs to lift it. When the door is at each hinge point and all the way up, it should stay by itsself. If it does not, the springs need to be adjusted or you will continue to replace gears.
Jan 22, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
When cold outside, door only opens a few inches
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Dec 05, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Door will only close when held down
sounds like the gear drive is getting worn.
also make sure the track are free of any debris.
Aug 17, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Not working
clicking noise usually is from relays on logic board. you over-heated unit. wait 25 monutes for motor to cool.
Aug 02, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener doesnt close the garage
If you have to hold down the button to close the door, you are bypassing the sensors ...
Check the alignment of the sensors. Should see a solid GREEN light
Nov 28, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Door won't go down
Yes ,your path may be clear and you might have two indicator lights lit,but remember that theese sensors are called a sender and a reciever,the sender send,s a signal to the reciever to let it know that alls clear and their are no obsructions , but i can tell you from experience that if your sensor has the slightest fliker it will not allow the door to come down as a safety feature that was incorporated in all machines by law from 13 years ago, First thing you want to do is find out which sensor is the reciever and this is very easy ,Just put your hand in front of one of the camera,s ....The one sensor that,s light goes out is the receiver, Thats because it is not receiving a signal ! Now I want you to make shure it is straight in it,s holder,aiming directly accross from the other sensor! Next go to the sender ,This beam is the crucial one and must be directly pointed at the reciever, notice the light on the sensor it is always solid and will not go out ,Next i want you to go back to the reciever and loosen up the wingnut that holds the sensor in the bracket , as you move the sensor up to down and left to right notice the light on the receiver become dim and bright and flicker as you move it from the direct path of the sender , this is exactly what i want you to adjust to it,s brightest light possible , after you have tightened it back up go over to the wallpad or doorbell that operates the door and see if your problem has now dissapeared , Thank you for letting me try to help you and hopefully we fixed together Sincerely Glenn Mayer
Aug 20, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
220 people viewed this question
Top Chamberlain Car Audio & Video Experts
Iron
Iron
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
