Question about Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil - Hampton Bay 24002 Ceiling Fan
  • Anonymous May 12, 2008
    I have a Hampton Bay fan (several years old) I don't see the model in the listings, however the motor makes noise and has since day one. Noise reminds me of maybe the bearings need lube, but I see no place to apply or inject oil into the fan Bearings.
    The noise is very noticeable at low speed, not as much at higher speeds.
    The fan I have has a Brass Housing with lights above and below the blades. The fan has 3 controls, 1 for lights above the fan blades, 1 for blade speed and the final one for the lights below the blades. Could SURE use some help here folks.
  • 20 Answers
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Posted on Jun 17, 2008
I have a Heritage Celing fan model M42UL. I connected it to work with the remote control. It does not work with the remote anymore. How can I reconnect it to work without the remote?
Make sure your dip switches match in the receiver & transmitter. If you have a wall switch, make sure it's ON. If there are pull chains on the fan, press the high on remote then pull chain until it's on high speed.
Aug 29, 2015 | Heritage Dryers
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Our ceiling fan is having a major problem it has an ac hum that goes right through you can you please help us to solve this problem?
Put a small piece of card board between the mounting bracket and the celing/outlet box. this will dampen the noise, and hopefully fix your problem.
Jul 11, 2010 | Aloha Housewares (93645) Ceiling Fan
My craftmade celing fans/lights start strobing
SOunds to me like you have a bad wiring connection in the fan unit, have someone check out all the connections, both between the fan and ceiling and the fan and light unit.
Jan 18, 2010 | Craftmade International Electrical...
R.kerr
Fan some times makes ratteling noise when it is old and dusty. If you know how to open it remove the fan put some oil in the bearing of fan give external supply to fan and run it for 5 mins. clean the ventilation behind fan if noise goes by oil it is good or replace the fan.
Nov 12, 2009 | Microwave Ovens
Equium P200-1ED.
yes the fan can be changed before that your noise making fan can be fixed only you have to do is that unscrew the fan first take small brush clean the fan leafs and blow some air from your mouth to the bearings and motor part put a few drops of oil or 2-3 drops of oil in side bearings and slowly rotate your fan with your fingre to and fro so the oil can reached to the bearings and it will get lubricated wait for five mintues and fix the fan back in position and you can use it ot need to add more oil to it again add 2-3 drops thats all once the fan is lubricated it will not make any sound in the future this is applicable to all cooling fan it is must that once in a year you should lubriacte the fans for better perfomance and it will get more life too.....
Oct 12, 2009 | Computers & Internet
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay 24002 Ceiling Fan Logo
1,529 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
