Question about Matsonic MS8137C Motherboard
No power at all
My friend lives in CA and built this computer from scratch for me. He used this mother board. I was getting an error on boot up that keyboard was recognized and floppy disc error (80).
Now the computer won't power up at all. I went out and bought a new power supply, but that did not help.
any suggestions?
  • Theocanj Apr 30, 2008
    The CMOS battery is the round battery on the mother board, correct? If so, I replaced it and still nothing. I guess I should try replacing the power supply now as well and perhaps both of them being new is the answer?
  • 385 Answers
Maybe your cmos battery has died. Buy a new one for about $5.00 and replace it. It is the battery that saves the settings for the motherboard but if it is dead the motherboard will get absolutely no power.
When you replace it, leave the power plugged in to the cpu for a couple minutes to charge up the battery and regain the settings and then try to power on the cpu again. If this still doesn't help then check the power supply.
Thanks,
Lolita
Posted on Apr 30, 2008
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Hi my pc come up with a error boot disk failure bit also i get a blue screen sometimes
You have given little information, but to me it sounds like your hard disk is failing. I would try to get the drive imaged to another one, and replace the drive before you completely lose all your data!
May 27, 2011 | Computers & Internet
I have an Intel E210882 mother board. Within a week, it was starting to become hard to boot, then I had to boot in F8 mode, and now when I turn on the power switch, the LEDs light turn on and the cpu fan...
If you have another computer that will hook up to the internet, download a copy of any live Linux CD (UBUNTU) and see if the computer will boot with that (you download a image file that burns to a boot able cd). If it will boot with a live CD, then you have a Hard drive / operating system problem. If it will not boot from that, you have a mother board problem. Start removing things from the motherboard, unplug and remove everything then plug hook up things one at a time.
Sep 18, 2010 | Intel Motherboard
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
I just replaced my power supply an after booting up my computer doesnt see any sound device at all, even though its been integrated into the mother board
My friend, I am glad you have identified your sound card. Remember, when dealing with a computer, it doesn't care what you know about it, the computer must know about it - where ever it is.
Please check your device manager to see if the sound device loaded properly and the driver is running. You will probably have to reload these drivers - get them from the manugacturer of the computer/mother board.
What ever happened was 97% not caused by the power supply replacement.
Thanks for your question at FixYa.com
Jan 15, 2010 | Office Equipment & Supplies
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Jun 22, 2009 | Computers & Internet
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
No Beep but boot up fine
possibly the on board speaker is disabled in the BIOS ?-
May 16, 2008 | Intel D865GBF Motherboard
Intel 945GCCR mother board network drivers problem
hi dear .
when start up the computer automaic run bios , when i exit it display this masseg :
reinstall jumber in normal mode .
and the jumber is in normal mode already .
thanks .
Jan 29, 2008 | Computers & Internet
Matsonic MS8137C Motherboard Logo
67 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
