Question about Acer Aspire 3610 Notebook
Touch pad quit working, fn-f7 doesn'make a difference
As above, touch pad quit working.....Fn-F7 doesn't help
  • 1 more comment
  • Anonymous Mar 21, 2014
    My think pad x61 has a black screen on startup and I tried everything I tried the fn and f7 I tried ctrl alt delete and the Lenovo button and took out the battery and charger and held in the power button for not than a minute but nothing is working
  • Anonymous Mar 22, 2014
    have tried the fn + f7 but still have dark shadow on lower right side of screen. any ideas?
  • Anonymous Mar 26, 2014
    Tried Fn + F5 and F7 does not work
    Scholar:
  • 33 Answers
First, ensure that the button that enables/disables the touchpad is not deactivated if your unit has one.
If the keyboard still works, and you can navigate past your log-in password and enter your windows environment, here is a quick way to check and ensure your laptop still has the correct software driver for your touchpad mouse.
1: Press and hold your windows key, and press the R key.
2: This will open a run command prompt. Type "devmgmt.msc"
3: This will bring up your device manager. It contains all of the software drivers of your unit. If your mouse has a missing driver, it should boldly stand out from the list as an expended menu, within either your mouse drivers, or unknown drivers. You should see a yellow asterisk or exclamation mark next to the damaged or missing driver.
4: If the driver is missing, you can often re-download it from the manufacturers website and have the computer automatically re-install it once you have the driver saved onto your computer.
This solution is only for a single scenario though. Why your driver would have gone missing should it in fact be missing or damaged would still be questionable. It is possible that another program, such as a malicious spyware or virus, could have modified or deleted it. If that were the case, simply re-installing it would not erase the software that is causing damage from your machine.
This is only a software related fix. If it is hardware related, such as the touchpad hardware itself is defective or damaged, then it would need to be replaced by a certified technician, most likely at a service center. I would recommend taking it to your nearest Best Buy and having a Geeksquad agent inspect it, test a usb or ps2 mouse with it, and give you a better idea of which of the two possibilities (hardware or software) the fault is really being caused by.
Hope that helps.
Posted on May 01, 2008
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Apr 10, 2013 | Acer Aspire Computers & Internet
How do I turn off the touch pad on my Acer Aspire 5742 laptop
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 01, 2011 | Acer Aspire 5742 Notebook
Touchpad not working
May be your touch pad is disabled.........
to check it .....
press "fn" key + F7 key
if ur model has F7 as the touch pad setting
Feb 12, 2011 | Acer Aspire One PC Notebook
There are not working the touch pad
Have you checked that the touch pad is enabled, as Acer uses something like the FN F7 keys to enable disable the touch pad.
If still facing the same issue means you need to download the touch pad driver from the Acer website and you can fix the issue.
http://support.acer-euro.com/drivers/downloads.html
Select the product and download the Driver.
Please let me know whether this works or not.
Dec 17, 2010 | Acer Aspire One PC Notebook
Touch pad not working
make sure touch pad is enabled (find the button on top most keys - may be f6 or f7 has a picture of pad and a finger) enable it by pressing and holding Fn and f6 or f7 .
give a try - if does not work then check device manager for drivers of touchpad
Oct 04, 2010 | Acer Aspire 5500 5570-2609 Laptop
Mouse pad will not work...only external mouse works....even though mouse is saying enabled on control panel
A laptop has a second function. It may be that you had accidentally clicked on Fn F7 or other laptops may have different Function to disable the mouse pad. You can determine that it is the mouse pad function because it shows a picture of a "hand in a square". To enable it, just Hold Fn then click F7 or different function.
Feb 03, 2010 | BenQ Joybook 5100U Notebook
My Acer emachine E627 the touchpad doesn`t work. what do?
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Jan 22, 2010 | Acer eMachines 520-2890 Notebook
My mouse pad isnt working but a USB mouse is, tried to use Fn+F7 but didnt work. Any help?
Is there a function key on the laptop? (Fn usually blue ink) is there a key with the symbol that looks like mouse pad. Hold down Fn then the mouse pad key and that should enable the mouse pad.
As you have suggested the F7 key is the one for the mouse pad, and hasn't made any difference, have you somehow corrupted the drivers. You can download them from the acer website.
when did it last work, you cloud try a system restore. Remember to press Fn + F7 again and give it a moment to enable( just in case the last time you tried it, you turned the hardware off despite it's lack of functionality)
Dec 29, 2009 | Acer Aspire 3000 Notebook
Touch pad
Hold "function (fn)", and "F7"... F7 should have a pic of a finger touching something...
Jan 17, 2009 | Acer Aspire 5520-5908 Notebook
Acer keyboard and touch pad doesn't work
I had the same problem. Do not put the battery back. It is damaged. You need a replacement. It is a battery surge that causes this behavior.
Sep 07, 2008 | Acer NSK8458AN Keyboard
Acer Aspire 3610 Notebook Logo
1,409 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
