I have a vusys monitor and for some reason when i plug it in to my computer it displays a message "out of range" and i recieve no picture any solutionfor this please?
    Problem Solver:
  • 10 Answers
Either
1.) The resolution/frequency your computer is currently running at is a higher resolution then the monitor can handle. Use a different monitor, if it works then lower resolution and replace with the vusys.
2.) You have physical failure. Your video card, cable, or monitor is bad. (Or you don't have it plugged into the right card). Try a different monitor if it works then and you did step one, then you probably have a bad cable or monitor.
Posted on May 01, 2008
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
Tip
Planar PX2710MW frequency out-of-range
After a computer reboot, about 8 out of 10 times the monitor would display a blue "frequency out of range" message. It would take several power off/on cycles for the monitor to finally display Microsoft Windows.
I called Planar tech support. They were super-nice. After about 15 minutes in which I shared my screen with them, the tech suggested I go into thePX2710MW's main menu (i.e. "Button 1") and then click "memory recall".
Problem solved! Wow.
on Feb 26, 2016 | Planar PX2710MW Monitor
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
RESOLLUTION ISSUES OR GRAPHICS CARD UPGRADE?
Can you please put forth the problem in minimal words?
May 07, 2009 | HP Pavilion a6650f Desktop PC
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
"Out of Range" Message
This happens when your screen resolution is set to something higher than what your monitor can display. For example, if your monitor supports resolutions of up to 1024x768 and your video card allows you to crank it up to 1600x1200, doing so will give you an error. Another reason you might get the error is if the refresh rate you selected a certain resolution is higher than what your monitor supports. The monitor can't "sync" with the video card, so it just gives you that "Out of Range" error. If you are sure you have your resolution set at a reasonable amount, make sure that your monitor is plugged in all the way. Actually, if you're like me, that might be the first thing to check. =)
If you are using Windows, hold down the F8 key while the computer is starting up and choose "Safe Mode" from the list of options that appears on the screen. This should force the display to be a low enough resolution so that it will work.
May 02, 2008 | Compaq Presario V400 14" CRT Monitor
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
