Question about Sony (MPF920-Z/131) Internal Floppy Drive
Floppy light stays on and will not read/write floppies
Just resurrected old AT chassis with Sony MPF920-1 floppy drive in it and installed a new Gigabyte motherboard, quad core cpu, etc.
Used cable that came with motherboard--with the twist in it.
Installed XP Pro SP2. System says the drive is working, but the light stays on and I cannot read or write a floppy. I even found another drive which I substituted with the same result.
I notice that there is a jumper on the drive. Anybody know what that jumper is for? And, does anybody have a fix for my problem?
Lee in San Diego
  • wise old owl Apr 30, 2008
    Thanks, oldnovii, for responding. I had just looked up the sony floppy drive on the web and found an installation guide. And, you were right on the money. I haven't hooked a cable up to a floppy for quite a while. I don't know if standards have changed or not, but what I found was that the new cable that came with the motherboard had the key on the connector on the wrong side of the connector and I just blindly plugged the connector so that the key matched the connector on the drive. But when I re-learned that pin 1 was closest to the power connector, I found that the cable was indeed plugged in backwards. So I had to 'force' the connector to go in with the key on the opposite side of the relief on the mating connector on the drive. That fixed the problem.
    I even went back and looked at some older cables I had laying around, and they are constructed the same way...strange...
    Thanks, again, for your help!
  • 667 Answers
It sounds like the floppy cable is hooked up backwards by the floppy drive. Take cable off at the floppy drive and turn it around and reconnect it. Let me know what happens.
Posted on Apr 30, 2008
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Floppy disk problem
Are the drivers for the floppy drives up to date?
Dec 05, 2007 | Sony (1QTY) Beige 3.5" Internal Floppy...
I have an IBM External USB Floppy Disk Drive that I'm trying to use to access some old files on floppies. Do I need special software to be able to use this? Or...can you tell me how to make it work? I'm...
this device is plug and play does not need any type of configuration basically you plug the device and the server (PC) would usually recognize it as the "A" unit
Aug 16, 2010 | IBM USB Portable Diskette Drive (05K9276)...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Computer does not detect a Alps Electric Co. Floppy drive
check the data cable and power cable,does the light in the floppy stay on if so you have the power cable the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
May 23, 2009 | Alps DF354H (DF354H168) Internal Floppy...
Asking to format
If this is a new floppy then its advisable to format it.
But if it has been formated before and the message still comes on then ignore it.
Also if you're denied access (Copy or Read) to the floppy then please reinstall the drivers and the floppy drive again using the installation manual
May 21, 2009 | Sony (MPF82E-U1) External Floppy Drive
Floppy drive light stays on all the time
please remove the floppy disk if inserted floppy drive...........or unplug the floppy drive .........or check the motherboard setting....some times light on due to reading floppy disk........please try it and rate it
Apr 11, 2009 | NEC (FD1231T) Floppy Drive
Disk error 13.01
This means the the floppy disk drive has dirty the reader/recorder heads, or the heads are misaligned, or the floppy has a mechanical problem during the reading process.
You can start in blowing compressed air inside the floppy disk.
If it does not work, then the floppy drive will need to be serviced or replaced.
Best regards,
Mar 17, 2009 | Sony Mavica MVC-FD73 Digital Camera
Sony (MPF920-Z/131) Internal Floppy Drive Logo
532 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
