FixYa.com
Tags:
Brother MFC-7420 All-In-One Laser Printer
Printer doesnt come out of sleep mode (Brother... (by 2 users)
posted by nick_ANT on Apr 30, 2008
hi there
i recently purchased a brother MFC7420 printer. The printer i connected directly to my PC and is set up perfectly as i can print, scan, fax etc etc. However, the minute i leave the printer idle for while it goes into sleep mode...then when i try and send another print job to it...it doesnt wake up....i have to turn it off and on to get it to come out of sleep mode. Have asked brother ..they said to upgrade the firmware....which i tried to do but it says i have the latest firmware...
please advise...
thanks
nick
Comment by nick_ANT, posted on May 01, 2008
Great stuff....ive done it and lets see how it works
excellent works perfectly
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 09, 2008
brother mfc-7420 will not all of a sudden not print from my computer
Best Solution
FixYa! (100)
eperez
Rank:Wiz Wiz
Rating: 87%, 17 votes
I'd be happy to give you the solution to this problem :)
You'll want to go into the menu and choose these options: 1,6, and 2. The final stop should give you the sleep menu.
The printer is setup for a default of 5 minutes. But you can change it from 00 to 99 minutes. To just shut it off, press the Options and Start button simultaneously and that will do the trick.
Here is the link to the manual: http://www.brother.ca/en/products/pdf/manuals/MFC7820N-UG.pdf
If I wasn't specific enough, the solution is on page 2-6
-Ernest
Rating Locked! (?) nick_ANT has rated this solution as FixYa!
Can you Help with these Printers problems?
OCR with Brother MFC 5440CN
I'm trying to OCR with my... Answer This...
Problem with Brother software.
After installing the MFC 7420... Answer This...
fax recieving faxs
Fax just keep ringing and not... Answer This...
reset toner TN2000
Can you send me a pictures of... Answer This...
programming speed dial
i want to program my fax to... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
