Question about Zenith Televison & Video
I have a Zenith VRE510HF vcr. When I power it on, the motor on the left spins for a few seconds, then the machine powers itself off. Prior to this, a tape cassette had refused to eject; I removed it by taking off the vcr's cover and easing it out manually.
  • dewflicky May 03, 2008
    This seems to be listed under "dvd", but it is in fact a vcr. I don't see how to move it to the correct catagory.
    Dewflicky
5 Suggested Answers
  • 537 Answers
SOURCE: tape stuck in vcr
If the tape is really stuck, your only resort will be to unscrew the cover off the unit and get to the assembly where the tape heads are. You can just simply pull the tape out (carefully). Some of the tape might still be spooled on the capstans or pinch rollers.
Mike
Posted on Nov 13, 2007
welcomejee
  • 10594 Answers
SOURCE: t.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Posted on Jun 22, 2008
SOURCE: Power shuts off
The problem is the reel sensor or associated cricuitry. I am an electronic tech and could not figure out what was wrong. I replaced sensor and sensor emitter with no change. It was not the micro. I finally gave up and told the customer I could not repair unit. No schematic or parts available from Philips/Magnavox
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Posted on Jan 02, 2009
farr64
  • 121 Answers
the letter R could be a fault code to that machine. depending on the deck installed a number of faults could cause it to instantly eject such as its not lacing the tape correctly or the deck as gone out of timing due to wear. the tape run pulses are not being detected due to senser problems .tray switches faulty ...even some thing fallen inside and jamed the deck like a label from the cassette.good luck farr64
Posted on Apr 27, 2009
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
I have a zenith dvd vcr combo. The tv I'm using
If no little switch on back, it must be a selection in the setup menu. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Jun 26, 2009 | Zenith XBV243 DVD Player/VCR
How to change vcr input from channel 4 to channel 3
On the Zenith, turn the power off. Hold down the Channel up or down button on the machine itself (not the remote) for 5 seconds, it will say RF03 hold down until it says RF04.
Apr 27, 2009 | Zenith XBV243 DVD Player/VCR
TV/VCR COMBO problem
My dear friend your problem is the charge motor belt who is in bad conditions you got ta replace him.Good luck.
May 28, 2008 | Zenith Televison & Video
Samsung DVD/VCR
It means that it is adjusting the sound from mono to hi'fi... probably because the tape is dirty/damaged or (more likely) the unit needs to be seriously cleaned. Try a cleaning tape, and if that doesnt work have a shop clean it.
Sep 20, 2007 | Kenwood DV-5050M Multi-disc DVD Player
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Televison & Video Logo
50 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
