Question about SAMTRON 55V 15" CRT Monitor
Samsung monitor colour complaints rectification regg.....
Thanks you boss.I tought my problem is  solved by seeing your  rectification method . I downloaded the ddcmanager/controller from ( one site .But i had one dought. tell me is that software works in winxp sp2 ,If not please give me the full details for that.
 please tell me where can i get the ready made controller or give the ckt diagrame briefly . ONCE AGAIN THANK U FOR UR RESPONCE.
  • Anonymous Jun 14, 2008
    control lock unlocked kommt als anzeige kommt und geht
    ist der monitor fefekt ?
  • 65 Answers
Hi, This is viswanath Ican give A/S Test Jig&Driver for All Samsung Monitors.It's Working Only Windows 98Samsung monitor colour complaints  rectification r - a36c108.jpg28f6cf1.jpg
Posted on Oct 15, 2008
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
Samsung 15 inch CRT color monitor it display everything in too green color while On...
Could be a pin is damaged in the 15 pin connector or the cable is damaged. Have you tried adjusting the colour controls?
Oct 17, 2009 | Samsung SyncMaster 551 15" CRT Monitor
I need to open the back of the Samsung TD220 LCD TV
Care is to be taken? these cases are engineered sometimes with interlocking panels see if you can wedge a a single edge razor blade between the grove of the mated panels and wiggle it see if it moves a little.
If so work it around using danty steps to find the interlocking area the rest is the tought part which one is the release side.
Jul 28, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 55v c/m colour problam
there are various softwares available using which you can solve this
Apr 17, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung monitor colour complaints.
all you need to do is download ddc manager bye using ddc controller you can reprogramme micom...
Apr 14, 2008 | SAMTRON 55V 15" CRT Monitor
The Red Colour Loss On My Samsung SyncMaster 753 DFX
My Dear Friends,
I Understood the problem.
I will explain it a little briefly.
There is an Integrated Chip (IC) inside the monitor which gave RED, GREEN and BLUE ( Primary Colours) to the CATHODE RAY TUBE (CRT) otherwise called monitor screen.
Due to long run, the IC might be cold soldered and one or two of the colours will not be supplied by the IC to CRT. so the CRT (monitor) will fail to display and mix the primary colours to get othe orginal colour.
The SOLUTION is to replace the IC with a new IC. As this requires a little bit expertise, please get help from the monitor service technician and ask him to replace IC with a new one. This can be done in home, so that you don't have to take the monitor to shop or service center.
All the things you have to tell the technician is to come with a stand-by ICs (NEW) for the MONITOR MODEL, in this case "SYNCMASTER 753S".
It cost around Indian Rupees 300/- for the cost of IC and another 200 Rupees for the service charge of technician.
I hope you solve this issue, if not write to me at with all details.
Spice Prince
Apr 10, 2008 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Color problem
1. if your monitor is old. due to aging it happens normally
2. Check monitor signal cable
3. Else the colour processing circuit is defective.
4. Check whether your monitor settings are set correct(default)
5. Contact monitor service centre for further rectification
Dec 22, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
145 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
