Question about GE Profile Harmony DPGT750EC Electric Dryer
INTERMITTENT DRYING DPGT750EC1WW, the blower works intermittently so that it fails to dry. Same problem as all these other guys. What is the fix? Dave
  • midas2311 May 03, 2008
       my dryer would work now and then, but now the blower motor dose not work at all, model # DPGT750EC1PL. if you havethe parts, please fedex,  thanks,  Pat
  • 172 Answers
Hi Dave,
I have recently had the pleasure of dealing with a couple of these and let me tell ya they can be a problem to trouble shoot. In most cases from my studies of this machine you can have one of two problems. One the blower motor is going bad and it will stop when it gets hot. When the blower motor stops the heat shuts off. Then when the blower motor cools enough it will start back. Unfortunatley it is usually to far through the cycle to still get the cloths dry. Possibility two is the blower motor controller. It is less expensive than the blower motor. I would recommend you replace the controller and see if the problem is solved. If the problem remains you will need the blower motor. I do have both parts on hand and I can give you prices and part numbers. Just send me your model and I will be glad to help.. Thanks and I hope you get back to wearing dry cloths soon.:-P Mike
Mca0824@aol.com
Posted on May 02, 2008
  • Michael Anderson May 08, 2008
    blower motor #WE17X10008 $176.00 delivered. In stock.
    Thanks for the fixya. Let me know if you need one.
    Mike Anderson Appliance Parts and Service.
    (865)945-3808
DE50F56E dryer stops drying and start/pause light flashes
There could be intermittent failure of the heating element.
Jun 28, 2016 | Dryers
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
HVAC Fan Blower Problem
sounds like the blower motor needs to be replaced.
Sep 05, 2012 | 2001 Lincoln Town Car
Heater fan not operating
Most of the time when a heater blower quits working it is the blower switch that fails rather than the motor. Blower switch can be accessed in the dash panel.
Feb 25, 2012 | 2004 Chrysler Pacifica
2001 T&C LXi - front blower fan is working intermittently
Hello! to answer your question; No...The intermittent operation is more than likely being caused by loose or oxidized contacts in the motor connector plug...Blower motor switch connector or the blower motor resistor plug...go to Radio Shack and purchase a product called DeOxit...cost $15...It's a two spray can package...A cleaner and contact protector spray...Cans are small you do not need much...Spray all three plugs; both male and female pins...You will notice a bubbling action...No wiping off...This is a no touch spray...This should clear up the problem...On the blower switch plug is a Black/Orange wire which goes to ground...Using an ohmmeter check this wire for zero ohms to ground...On the X10 scale...If you do not read zero ohms...The connection of this wire needs to go to bare metal chassis ground...
Guru...saailer
Feb 07, 2012 | Chrysler Town & Country Cars & Trucks
Wte 86300US/05 dryer is not drying clothes shows f.03
This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Jan 09, 2012 | Bosch Axxis WTL 5410 Electric Dryer
Dryer heats to proper drying temperature and then temperature is not maintained and drops off causing long drying time when on timed drying...GE Medallion 850 - bottom heat sensor was cleaned.
you didn't mention if dryer was gas or electric. gas dryer could have bad valve coils which will work for a short time and then fail, cool off and then work again and fail, causing intermittant heat.
May 05, 2010 | Dryers
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
Hotpoint CTD85A F15 error not drying clothes
Hi
f15 means heater relay on pcb is welded closed
which basically means the pcb has failed and needs replacing.
regards
Mar 22, 2009 | Hotpoint Dryers
Gas dryer not heating
Try new gas valve coil packs they are inexpensive, and easy to install and fix 90% of intermittent lighting complaints
Oct 15, 2007 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
274 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
