SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
SOURCE: one short beep two long beeps redlight on startup
RAM usually goes in pairs. Do tests with two sticke. They have to be identical
SOURCE: no video & keyboard wont light up. MSI p6n sli platnium
It sounds to me like you are right with the motherboard being bad, however, before you try that, try re-seating the memory. Also, try just putting 1 memory stick in. If you do both of those and still nothing, then I would definitely look into getting a new motherboard because that probably is your problem.
SOURCE: MSI K8N Neo4-F Motherboard power on but ,not post
At this point I would try another processor and if you still can't get video with another known good working processor then that means the motherboard is bad. Also check for puffy capacitors, that would cause the motherboard not to post as well. If all the capacitors has flat heads on them then the motherboard is still bad.
SOURCE: Brand new G31M3 V2 MSI motherboad, fresh out the
Remove everything except CPU and 1 stick of RAM. Attach monitor to onboard graphics and under Integrated Peripherals in BIOS there SHOULD be option for display, it needs to be set to PEG so it looks for a PCIe graphics card first. If you still get no picture, DOA motherboard.
