My s100sp canon printer prints in light grey, not black. Can I get it to increase the density of the black cartridge? It's printing evenly, so it's not running out of ink, and I've mucked round with the colour settings.
Please help me my computer can"t support my printer s100sp.What can i do? please help me.....
Posted on Jul 07, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Apr 04, 2013 | Canon MF6530 Black and White Copier
Canon MX340 I just replaced the ink (black and color). Black now prints in grey. What to do?
if you put a refill cartridge the printer are printing in grey.Try to put original cartridge canon.
Mar 09, 2011 | Canon PIXMA MX340 Wireless Office...
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
OKI c5100 Printing GREY instead of BLACK.
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Jan 12, 2008 | OKI C5100n Laser Printer
265 people viewed this question
k24674
