Need Hight voltage Transformer for RCA TV. Model NO. G35831AT
  • 8,617 Answers
You can get the replacement Flyback for your model at the following link, and it comes with free instalation instructions and free on line tech support. Just click on the flyback section and you will find the one for your model number.
http://servicemanuals.vstore.ca/
Posted on Apr 30, 2008
Tv wont turn on
If the model number listed here is correct check the fuse and then look under the high voltage transformer for bad solder connections which is the most common issue in the model listed here.
12_17_2012_3_48_38_pm.jpgTypical high voltage transformer.
Dec 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
RCA G35831AT
This is a loss of the "pincushion correction" circuit. These sets are known for bad high voltage capacitors in the horizontal circuit that cause a loss of pincushion correction. It could also be loose solder connections in the horizontal circuit. This can be a dangerous circuit to work with. Have a shop check it for you. Thanks for using fixya.
Jan 11, 2010 | RCA G35831AT 35" TV
No power
Check ur power source,might need FBT,flyback transformer,the big plastic block with a red wire with a cap hook to a CRT(tv tube).Hight voltage.
Oct 07, 2009 | Samsung CW29M64NS 29" TV
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Aug 25, 2009 | Sony KV-32S45 32" TV
Tv turns on and off
Maybe it´s the IC regulator of the tv need to change it or the eeprom corrupted
Aug 16, 2009 | Zenith C27A24T 27" TV
Ctc 179 service program
No need for the answer I have the setup instructions for the rca tv. I am a tv and computer technician and always carry a sheet with these instructions as I work for company like Sears on tv, projection tv, audio and other electronics, thanks for the help.
Dec 30, 2008 | RCA G35831AT 35" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
RCA G35831AT 35" TV
The G35831AT uses the CTC179 series chassis. When you touched the wires to the speaker jacks you probably somehow managed to short out the audio output IC, which would have sent up some smoke. When the set is turned on, the computer senses that the audio output IC is shorted and shuts the set down. The audio output IC should be replaced and all other circuits checked by a qualified tech familiar with the 179 chassis.
Aug 21, 2007 | RCA G35831AT 35" TV
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
