Tv powers up , very good sound but no picture, what could be wrong
  • 8,617 Answers
Try re-soldering the vertical output IC
Posted on Apr 30, 2008
Vizio tv mod# SV470XVT1A has good picture but no sound. Replaced the sound board but still no sound. tried all the troubleshooting steps to no avail. What could be the reason that there is no sound?
Try the sound settings. You might have wrong format selected. Also make certain the speakers work.
Otherwise it could be a problem on the main board, or the power supply board that provides the power for the sound board.
Apr 03, 2017 | Vizio Televison & Video
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
My Vizio 55XVT1A power on, has sound, but no picture. I changed new power board, main board, T-cond board, but it still same problem. What's wrong with it? Is it anything with inverter board? Than
If this is an LCD tv the backlight inverter is bad, a good way to check it is to shine a flashlight close to the screen and see if you can see a faint picture.
Let me know what you find
Feb 18, 2012 | Televison & Video
Picture and sound go off and power indicator blinks eight times. TV will not turn off or back on. Disconnecting power for a few seconds restores the picture and sound for a time, but then it repeats.
The TV might be telling you that there's something wrong with the power (wrong or excessive voltage, for instance). Please test the TV at someone else's house to rule out electricity problems at your house. If the TV still shuts off, then there should be something wrong with its logic board or power circuits, and you should call a technician to inspect it.
Mar 02, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
NO Picture or Sound
sounds like someone rolled over on the remote. if you have cable or a dish, the tv channel must be left on a specific station at all times. no matter what channel is on the cable, the television itself must be on the correct channel number in order to receive he signal from the cable company. try hitting the last channel recall button on the tv, not the cable. otherwise try channel 3 or 4 or sometimes 60 on the tv. good luck
Nov 11, 2009 | Televison & Video
My hitachi turns on and has a red/green glow, but no picture on it. It sounds like it is running, but there is no picture or sound. It recently had a power surge go through it. What could have gone wrong...
have you checked the bulb in the tv? sounds like the bulb is no good they are around 40-60 bucks...make sure tv is off and unplugged before checking and dont touch it just look to see if its blown
Jun 04, 2009 | Hitachi 60V500 60" Rear Projection...
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
Sound, but no picture
Locate vertical output IC = solder all pins = two off-set rows,
then try again................part location IC301 , or 401 ?
2) possible bad CRT = turn up screen voltage slightly = did pix pop back on ?..................................T.
Please rate this solution.........................
Feb 09, 2007 | Sony KV-27V22 TV
Picture is VERY dark...
zenith have many problems with crt (picture tube) they comes be short or one or more canon fail, there are nothing to do, replace the picture tube, and thats a lot of money for an old tv...good luck ps adjusting the screen and resoldering the picture tube card could help but remember there are many dangerous circuit in a tv...
Aug 10, 2006 | Zenith C27A24T 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
