Question about RCA F36668 36" TV
TV clicks/snaps and won't turn on
My TV won't turn on and it doesn't matter if I use the remote of push the power button on the front of the TV. It clicks continually unless I hold down the power button on the front for at least 20 seconds. I called a couple of local repair shops and received an estimate of $250-$300 and it would take 3-5 days. Is this something is relatively easy to fix?
Thanks!!!!
  • gmw1 May 12, 2008
    plug the tv in and it has a beep every almost every second but can't turn it on. Unplug it and it beeps twice ore slowly then stops.
    Is it worth fixing?
  • huskerdean Aug 28, 2008
    tv shut off and won't turn on. it just "chirps and clicks". RCA repair man changed the transformer and transsister. charged me $227.90. it works fine now.
  • RCA Master
  • 5,138 Answers
Did they say for sure what parts are bad? My guess flyback transfomer/ shorted hori output transistor NTE2324.And to answer your other question about you trying to fix this keep in mind this set carrys up to 36,000 volts and if you really dont know what you are doing can get you killed.leave it to the PRO's to fix unless you have at lease 3yrs of Electronics.
Posted on May 01, 2008
Tip
How to get OSD on TV for a Pioneer Receiver
OSD for on your TV for a Pioneer Receiver setup menu. (It doesn’t matter what make your TV is).
Connect the MONITOR OUT video jack on the receiver to a video input on your TV. Use a standard RCA video cable to the composite video jack.
Turn your TV on and put your TV onto AV3. Turn your receiver on, then on your remote control push the receiver button (this is not the on/off button, there is another button with receiver written on it) then push the setup button on your remote control. You should get the OSD menu on your TV for the settings for your receiver.
on Jan 03, 2010 | Audio Players & Recorders
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I lost my bratz tv remote annd i finelly got cable but need the remote to turn it on.What do i do??
Most TVs have a power button located on the front of the TV that you can push to turn it on. If your TV doesn't have one, you could buy a universal remote and use that or buy a new tv.
Jul 18, 2011 | MGA Entertainment Bratz TV
Model: 32A43 Problem: Volume goes UP automatically. Channel scolls automatically. I tried using the remote and the buttons on the tv panel but neither works. I tried turning the TV off with the remote and...
check the front button plate on the front of the tv very carefully.if it has been hit with something and either or any button is pushed in,it will not listen to other commands.make sure each button has a distinct click when pushed.a frozen button will cause other things not to work.it sounds to me like two buttons are making contact,and they are beside each other,so the button plate is crooked or warped.
Jul 18, 2009 | Toshiba 32AF43 32" TV
I cannot adjust the volume on my Samsung 42" Plasma (PN42a400)
The fact that it turns on is good. Most likely the trouble is with a data line internal in the set. It may be the remote receiver IC or a push button on the set. A stuck button or switch can confuse or load communication between internal microprocessor circuits. Take a look or feel each of the push buttons do they feel the same when pushed ? Do they have a slight snap when pushed. The tac switches used in most cases are made like a small old clicker. If one feels soft and has no snap it's probably your trouble. If so tap lightly around but not on the button and it might free itself. You should just have Samsung replace whatever is the cause.
Apr 21, 2009 | Samsung PN42A400 42 in. Plasma TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
RCA F36668 36" TV Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
