The rubber on the inside of my washing machine has some black mold build up. What can I use to get rid of the mold that won't hurt the rubber?
  • 1,073 Answers
Lemond juice
Posted on Apr 30, 2008
We have mold along the inner rim of the rubber gasket between the opening and the door. How can we get rid of/prevent?
Robert, You can buy or make up your own mold Rid/ cleaner, which you will spray on bad areas and wipe off. Tip if possible leave washer door open so trapped moisture can air dry.
Check the attached links, for mold Rid/cleaners.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Concrobium Mold Control 946 mL The Home Depot Canada
Amazon com CLR PB CMM 6 Mold and Mildew Stain Remover 32 oz Spray Bottle...
Mar 10, 2016 | Bosch Vision 500 Series Front-Load Washing...
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    Neptune washer front door seal has black build up
    Try pouring a cup full of distilled white vinegar into the soap dispenser drawer while it is filling up on a hot wash. Don't put any washing in, just let the machine go through the full cycle. Repeat if necessary.
    You may be able to scrub lightly affected areas of the door seal with a scourer or old toothbrush etc. and something like Jiff. To be on the safe side you should wear goggles and a mask when dealing with black mold.
    It may be worth trying a black mold remover available from supermarkets but read the instructions to make sure it is safe to use on rubber if intending to use it on the door seal. If badly affected - the only way to get rid of it - is to replace the door seal.
    Nov 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
    I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
    Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
    There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
    The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
    The only way to remove is by replacing the door seal.
    If you try bleach etc then it will cause the mold to get worse.
    Hope this helps
    Aardvark Repairs
    Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
    My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
    Clean with bleach solution and a Mr Clean Magic eraser.
    leave the door open to dry out the machine from now on.
    Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    I have a Creda W200FW. The rubber packing of the front door is full of black mold and smells bad. What kind of detergent is good to get rid of them. I have moved to a renging house and the washing machine...
    Hi , Bleach will get rid of the black mold and stop it coming back for a while. Don't leave it on too long as bleach has a hardening effect on rubber. If you occasionally give it a wipe with a mild bleach based cleaner it will stop it coming back.
    Jun 08, 2009 | Creda W100FW Front Load Washer
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Mold around the rubber seal in the front loader. how to get rid of
    aliitle amount of vbleach on a damp warm rag shoudl remove the "mold", cut back on the amount of fabric softener and make sur eyour using an HE detergent ( A MUST FOR FRONT LOADERS)). keep the door ajar between loads will also lessen the build up
    Nov 06, 2008 | Washing Machines
    Washing Machines Logo
    61 people viewed this question
    Top Washing Machines Experts
