GFI usually trips from unequal current levels between the hot and neutral lines unless the saw starting-current-draw is more than the ampere rating of the GFI breaker. You may have to wire a special circuit for this saw if it is a heavy duty unit. If the previous owner was sawing metal, that can leave particles within the motor that may cause electrical leakage to ground which will trip the GFI. Hope this helps!
