Question about Filter Queen Majestic Canister Vacuum
Don't know how to change attachments
Hi just brought used majestic 360 but can't change the attachments. The metal pipe is too big for the attachments there seem to b part missing ???
  • 2,794 Answers
Can you take a photograph of the attachements and send it to this e-mail address:
timbacock@earthlink.net
I need to verify what you have to determine the problem.
Posted on Jun 09, 2008
Power nozzle has quit working
Most of these nozzles have a reset button on them. Standing behind the nozzle it is on the back, right side.
Dec 30, 2012 | Filter Queen Majestic Canister Vacuum
Does not pick any thing up
Check the filter and the hoses for blockages and clogging. If you can, **** backwards through the pipes to dislodge any foreign stuff stuck in them. See it there is suction when the hoses are removed, this will tell you if the hose is blocked. Also check the attachments you are using in case they are blocked. Using a vacuum that is not sucking means that there is no cooling air going over the motor and it will overheat.
Mar 22, 2011 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
I don't think it is suctioning right
start by checking the filters on the unit. The filter cone and the little disk filter just above the cone are the perfect place to start.
Next see if there is something in the hose that may be blocking it. On this machine you can reverse **** the hose back into the canister.
look down the metal pipes for anything blocking the airflow there as well.
IF all of that is clear, and no blockage in the piping, then you may need to replace the belt on the power head. A lot of times this will stretch and not allow the unit to pick up properly.
Good luck with that.
Mark
Nov 12, 2010 | Filter Queen Majestic Canister Vacuum
The beater assembly on our Majestic 360 is not working. We've pressed the reset button, checked the belt, made sure the connections were complete. Suction is reaching the unit. What's our next step? Thank...
Check the power cord going to the unit with a volt/ohm meter. The wires break, UNPLUG and take plyers and slightly squeeze the female connections, and plug in again.
Oct 07, 2010 | Filter Queen Majestic Canister Vacuum
I'm lookinf for a owners manual for a 70th anniversary Filter Queen Majestic canister vaccuum. My sister in laws mother died and I bought it from her but she can find the manual.
Hi There,
Here's a link to the owners manual for your Filter Queen Majestic:
http://www.filterqueen.com/pdf/majestic.pdf
This may be a little newer model, however this instructions and use of this machine will be identical to the one that you have. They really have changed anything on their machines other then the looks of them for a decades.
Hope this helped! Please be sure to rate my repair helpful, or leave feedback if this answered your questions.
Chris Jones
GoVacuum.com
Apr 26, 2010 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
78 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
