Question about Panasonic TC-20LA2 20 in. EDTV-Ready LCD Television
Pana TC-20LA2 LCD TV Blanking Video
When just turned on the video is fine. After a while the video flickers and then goes to black. This is the same for all input signals but you may see very dim diastorted video if at all. The audio is very muted. Note: The menu is still viewable! The video may come back. It doesn't seem like a tuner issue. TV is 2.5 yrs old and is bright when viewable. Don't have a schematic but is there a common condition / part failure like this?
  • 3 more comments
  • win7064 Jun 13, 2008
    UPDATE: The video is permanently gone just some very dim ghosting if anything. Very muted audio still. Good menu. Seems the backplane may be good. Maybe it is the tuner? I can do electronics repair.
    Panasonic still shows a parts list on their site for this model.
    Thanks, been there already and have another TV in place to test the signal.
    Same issue, verified good signal and connection already. Thanks. Any more ideas?
  • win7064 Jun 18, 2008
    Looks like I'll have to buy a schematic or take it in. Can, anybody else verify a like problem / fix ...LCD Inverter problem. Last shot, Thanks.
    Master:
  • 788 Answers
It's not the inverter as that would not affect the sound. If it's on all inputs it's not the tuner. It would be logical that it would be caused by whatever board drives the LCD.
Posted on Jun 18, 2008
  • 4,234 Answers
Since this is an LCD based set, there are twqo components that must work in order to get a picture; the LCD panel itself and what is often referred to as the "back light". An LCD works by letting differing amounts of light through the crystals. If the "back light" has failed, you may still be able to see an image, but it will be dim (similar to what you describe above). There are a number of reasons for this type of failure. Based upon the description you supplied, I would first be looking for bad connections that may have been caused by heat. I can not rule out component failure, but the less expensive route is to look for bad solder joints first.
I am assuming that this set is out of the warranty period.
If you need additional info, please do not hesitate to ask.
Dan
    Sergeant:
  • 243 Answers
Try and retune Channel(s). It does look like this is a somewhat common problem. You might be better off replacing/upgrading it at this point.
Thanks,
Lee
  • Panasonic Master
  • 13,433 Answers
Seems the lcd inverter gets tired after a while and would need to be replaced, it may also be some other component on the display which is causeing this, no easy fix for this one.
  • Ekse Jun 18, 2008
    repair or replace parts. needs to be inspected inside to pinpoint the issue.
    Master:
  • 848 Answers
Since your tv is 2.5 years old there is possibility of part failure better call the company people to check the parts of the tv
Posted on Jun 13, 2008
  • gopinath pasupathy Jun 23, 2008
    try this to check lcd inverter problem
    Get one of those CCFL lights like they use to mod cases with that has a bulb about 12" long. Connect the bulb to the inverter to check it's output and the new inverter to the backlight to see how it looks.
    Master:
  • 555 Answers
Make sure that your input source cables are firmly secured. It almost sounds like a bad input connection that slips over time.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
How to unlock the child lock for panasonic tv tc 20lchow to unlock the child lock for a panasonic tv model tc 20lc
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 02, 2015 | Panasonic TC-20LA2 20-Inch Flat Panel LCD...
Coulor fluctuation
Most likely the main board which processes all information including audio and video and chroma or color.
Dec 04, 2012 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Video flickers on and off
Bad capacitors in the unit that are in the signal board.
Sep 09, 2012 | Samsung LN32B360 32 in. LCD HDTV
HAVE A PANASONIC TC-20LA2 LOUD SOUND COMING FROM REAR OF TV AND NO PICTURE, ALSO A LIL SMOKE COMES FROM TOP VENTS AND SMELLS LIKE ELECTRICAL
That will be real expensive repair jobs, it can be from the power supply or from the backlight inverter circiuts. I would leave it unplugged.
It will cost too much to have it done at the repair shop, it is only 4:3 screen also. You may want to think about it first.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 26, 2010 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
I have a Panasonic TC-P50S1 Plasma HDTV. I am trying to run my PC into it via DVI to HDMI. It will work, sort of, for a little bit. Then eventually the screen flickers and I lose the picture completely. I...
I BELIEVE THE ISSUE IS THE RESOLUTION THAT THE VIDEO CARD IS SET AT. IF YOU ARE USING THE SAME RESOLUTION AS THE PC, IT WON'T WORK.
TRY SETTING THE VIDEO CARD RESOLUTION AT 1920 X 1080. THIS SHOULD WORK.
ED P
Jan 20, 2010 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Panasonic tc-20la2 black screen
Try calling up a Menu for Picture on the screen with your remote.  Also check that it operates the TV and not the VCR or DVD player.
Good luck.
Dec 06, 2007 | Panasonic TC-20LA2 20 in. EDTV-Ready LCD...
Panasonic TC-20LA2 20 in. EDTV-Ready LCD Television Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
