Question about Breadman TR875 Bread Maker
Breadpan Stuck The breadpan in my TR875 is stuck and I can not get it out. Suggestions?
  • mikescoe Jun 01, 2008
    Mines brand new and I have the same problem, the pan came out before I used it for the first time and now it's jammed in there. Never ran dough through it ran it empty the first time as the manual suggests.
  • Anonymous Aug 27, 2008
    Same problem, found a quick fix. Run it on the bake cycle for 3-4 minutes to get it good and hot and it pops right out. Now comes out easily.
Put your breadman on a surface low enough that you can look straight down on the pan and the machine.
On each side (L/R) there are thin aluminum "wings" that hold the pan in. The pan should be placed straight down and pulled straight up.
Adjust if you can-do remember that there is a "peg" in the center of the machine, so don't break it.
I had to fuss a little to get it straight and then lift it out.
Posted on Aug 17, 2008
The kneading machansm ell not rotate
If you remove the pan and reach underneath it and grab the little" ears" and try to turn them does the shaft rotate?
Dec 31, 2012 | Welbilt ABM3500 Bread Maker
The Breadmaker is not working properly
If the finish is worn and damaged and rust is impeding turning of the spindle you may wish to consider replacing your breadpan.
try contacting the Toastmaster parts supplier to see if they have a breadpan for your model. You can make a web inquiry here:
http://www.partsourceplus.com/contact_us.php
The comnpany does have parts for many other models so there is some chance they may be able to provide a compatible breadpan. For reference:
http://www.partsourceplus.com/toastmaster-parts-accessories-bread-makers-c-51_1268_1277.html
Oct 23, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
The mixing blade is stuck in the tin . How do we get it out?
Try soaking it over night or even for a couple of days. Put just enough water in it to cover the paddle completely plus about an inch with a little detergent. Whatever you do don't try to pry it loose with anything metal because you will damage the nonstick coating on the paddle and/or the breadpan!!!..............If it still won't come out log on to you tube and type in "How do you remove a stuck bread machine paddle" ......you will see my video of how to remove a seriously stuck bread paddle with no damage to your pan or paddle.
Oct 10, 2010 | Sanyo SBM-20 Bread Maker
Paddle shaft unable to rotate in the breadpan.
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
May 11, 2010 | Black & Decker Bread Machine
Sunbeam 5891 breadpan is rusty, sunbeam doesn't sell?
Unless you are lucky to find one at a tag sale or something, I would go new. I looked everywhere for a replacement and they were expensive. Bought a new one at Wally Mart in NH for $53.00.
Oct 28, 2009 | Kitchen Appliances - Others
I managed to scratch the loaf pan and am looking to buy a replacement for my Tr520 Breadman breadmaker. Not proving to be very easy. Help!
Check out ebay. They seem to be expensive....For some reason I think the manufacturers don't sell the bread pans separately so you have to buy a whole new machine.
http://cgi.ebay.com/NEW-Breadmaker-Bread-Machine-Pan-Breadpan-TR875-TR520_W0QQitemZ380140130482QQcmdZViewItem
Hank
Aug 31, 2009 | Breadman TR520 Bread Maker
I have a locked up breadpan. Need another
This happened to me also. I looked on Ebay but they were so expensive ($19.95 + $10.00 s/h) so I just went to Walmart and bought a new machine for $52.00. Seems they don't provide new bread pans so you have to buy a new machine. Oh well. Not a true solution, but hope this helps.
Someone posted a comment that they soaked the pan overnight in soapy water and it freed up.
Hank
Aug 11, 2009 | Sunbeam 5891 Bread Maker
Breville breadmaker model BR1 breadpan
seems like we all have the same fault with this breadmaker - and we all cant find the solution easily - looks like breville really dont have much of a customer care section do they - i suppose they think you should just go out and buy a new one -i am still hunting for a new pan and paddle - looks like they're as scarce as rocking horse **** !!
Jan 12, 2009 | Kitchen Appliances - Others
Where can I find a replacement breadpan for the breadman tr2200c?
I found the part at
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
http://www.saltoninc.com/
Nov 13, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR875 Bread Maker Logo
228 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
