Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blinking Power light on Sharp Aquos
Jerryg50,
I have a 37" Aquos and the TV will not turn on. I had a tech look at it and said he did not know what could be causing the issue. I read some forums and decided to try to self-solve. I replaced the power board and the control board and did not repair the issue. I reboot the TV and prior to the clicking and shutdown the "K" is visible. So, this tells me that that backlight is working. What else could it be?
Thanks,
Mike
    Genius:
  • Sharp Master
  • 1,667 Answers
You should contact Sharp to find out where you can send the set for factory service for your area. They work by territories. The local repair tech would not normaly be trained and equiped to service this type of set.
The fault can be on a number of boards, including the main processor, or the matrix drive, or right on the backplane of the screen. The boards interact with each other and talk to each other using their own processors and a data buss. The backplane of the screen is using enbeded technology for the LCD drive itself.
Trying boards on a guess will end up being much more costly than sending the set out and having it proberly serviced. Also, at home you would not be able to perform any of the factory level adjustments if necessary.
Jerry G.
Posted on May 04, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
My sharp aquos tv power light is blinking but it donot power on.try to reset by presing and holding down the volume and chanel.but dint work,
Could be the powerboard, try unplugging in and leave it off and unplugged overnight and try it again. If this doesn't work see and tv repair tech.
Jan 26, 2015 | Sharp Aquos Televison & Video
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only...
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
May 06, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Apr 26, 2010 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
TV wont turn on blinking power light
The powersupply is going bad. If it's within a year old it's probably under warranty, if not look on ebay for "aquos lc32g4u power supply" or "aquos lc32g4u parts" and then replace the powersupply.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Jan 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
685 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
