Question about Memorex MT2274 27" TV
Simple. I need an eprom for this model.
DEAD EPROM
    Problem Solver:
  • 8 Answers
Try checking with eServiceInfo.com, as I believe they have the service manual (as opposed to the user's manual), which ought to list the eprom, for free. If not, you may need to buy the manual, which is available from ManualZone.com for just under $20.
Hope this helps in some small way.
Linda T.
Posted on Mar 15, 2009
E-prom
The set has more than one eprom...
With the model number AND the location number of the eprom (location number is marked on top and bottom of the board) GOOGLE FOR THIS INFORMATION.
Mar 27, 2012 | Panasonic CT-32SL14 32" TV
Need to purchase eprom 1.27and installation instructions and whatever comes with it. for alesis masterlink 9600, I have contacted Alesis, they are too slow at service at this time.
If you are very sure that the problem you are facing is generated from eprom only then go ahead with this.
As per my experience the best way to replace eprom is to find a similar motherboard with similar eprom version and replace the eproms.
You can also buy a eprom from the market but again you will have to program that eprom for which you will need the eprom programmer, an electronic device which feeds a script in eprom and also you will require the script.
Sep 20, 2011 | Computers & Internet
I deleted my bios how do i install my bios
The software in the BIOS is stored on an EPROM (Eraseable Programmable Read Only Memory). So, buy some hardware, namely an EPROM writer, remove the EPROM chip from the motherboard, insert the EPROM chip into the EPROM writer, download the latest BIOS-software from IBM's web-site, and load the software onto the EPROM writer, and rewrite the software onto the chip. Remove the chip from the EPROM writer, and reinsert it into the IBM motherboard.
Jul 17, 2010 | IBM NetVista PC Desktop
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Old zenith 1999 model got from a hotel the program channel is locked can i unlock it
When you locked a tv you need the password, if you not get it, you will have replace the Eprom chip whith another recorded Eprom chip in acorded whith the tv model number.
Feb 28, 2010 | Zenith Televison & Video
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Child lock or tv lock code on. don't know unlock code. bauer 37cm colour tv. model c3718s
If the child lock code no longer responds it would suggest data corruption to the Eprom. The Eprom programme specific to this model should be re-written using an Eprom writer or otherwise a new programmed Eprom for this model will have to be replaced.
Aug 31, 2009 | Televison & Video
Philips rear projection TV model 60P8342.
It`s not Eprompt, it`s the Eprom, Erasable Read Only Memory. The Eprom holds all the information in it about your set like has it got Ni-cam Sound, A wide-screen, A projection set plus a lot of other information like Convergence settings, RGB setup, PAL, NTSC settings plus customer settings like Colour, brightness etc. There are other settings besides these which are in binary bit code which can control the power supply, Standby timing etc etc. The Eprom may only be an eight or a sixteen pin device but it a crucial part of the set where information is perminantly being read from the Eprom to make sure the three guns are set correctly and the convergence errors are being kept in check. This is a very time consuming job even for a qualified technician, I know, I used to do these and Philips sets are notorious for Eprom and uPC failures. The Eprom comes formatted from the suppliers, so there`s absolutley no information in it at all meaning that you have to start from zero. If you can get the set to come on long enough and you can get the set into service mode, you may be lucky where you can write down the 200-300 or so settings, If not, WHAT A JOB. Believe me, you can change the Eprom in 2 minutes, but it could take 1 or 2 days to set it all up again and even then it`s very difficult to get it perfect. Ian
Aug 10, 2009 | Philips 60P8341 60" Rear Projection...
TV RCA THOMSON 27R411T CHASSIS ITC008FHM
Try replacing the eprom. If that somehow became corrupted due to HV surge or otherwise, you would have this symtom. The eprom contains information that basacally tells the HV circuit to turn on.
Apr 06, 2009 | RCA 27R411T 27" TV
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Memorex MT2274 27" TV Logo
67 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
