Question about Dell Inspiron 1000 Notebook
Power supply When I turn on my computer it starts but it turns off moments later by itself. Also when the laptop is on, the screen goes black, I usually just fold the top down and up and it goes back to color. What is going on?
  • Anonymous Jun 04, 2008
    The same here! Changing the bettery, stripping the pc from the memory module, HD, CD drive - doesn't help!
    Shame!
  • 34 Answers
Your motherboard is having issues and needs to be repaired. If you are not under a service plan or warranty... buy a new laptop.
Posted on May 01, 2008
My toshiba Satellite l455d-s5976 will power up but screen stays black. Now this problem has been reoccuring since maybe last week where my stepfather left it on and it locked itself. I tried to turn it on...
when the laptop is off hold the power button until 1) the screen goes on or 2) it turns on. if 2 then try connecting a monitor to the laptop and reboot.
Sep 07, 2013 | Computers & Internet
I left my computer on and around a half an hour later i returned and the screen was black, i played with the mouse pad - nothing. turned it off then back on - nothing. did that around 100 times -...
Difficult to give an 100% positive solution, but try a cold re-start ie: Turn the power supply off, remove the battery, wait 20 seconds, replace the battery , re-connect the power supply, switch on. All being well the PC should start up normally.
Oct 02, 2009 | Toshiba SATP L300D Notebook
Problem with my display its black
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply.
Aug 18, 2009 | Dell Inspiron 6400 Notebook
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Dell Inspiron 1000 Notebook Logo
37 people viewed this question
Alun Cox
