My Medion 32" LCD Flatscreen television will not switch on from standby!
    Genius:
  • 3,422 Answers
If the power light is flashing and the screen wont come on then the power supply is failing and you will have to call an engineer to fix it up.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 30, 2008
  • 2,322 Answers
There are a few members reporting the same issues with different brands of LCDs. The majority have power supply failures due to the amount of heat that is generated when the TV is on.
A good number of power supplies can be fix to the component level, since there are not many places that carry the service parts to fix the TVs.
I would suggest to try to find a TV technician to fix. This might not be a DIY project.
If the TV is less than a year old still under manufacturers warranty.
Good Luck.
    President:
  • 2,712 Answers
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. A PCB may crack about some of the larger components. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
2. Powering down the set fully may have also allowed the power supply to cool, weak capacitors often go out of spec when they cool, this preventing may have prevented a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
3. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
4. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a pic:
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified techie to do it for you.
Clearly, electronics expertise is needed at this point, and if you had electronics knowledge you would have solved the problem already :) So I don't recommend poking around on the inside unless you know what you are doing.
LCD TVs do not have high voltages inside like the old CRTs, but power line voltages may still be present and give you a bad shock.
Also modern CMOS integrated circuits (or chips) inside digital equipment are very(!) sensitive to over-voltage, short circuits or even static electricity. The simple act
of touching the wrong chip with your fingers can destroy it. A static shock too weak to give you a tingle, is strong enough to blow the integrated circuits inside your TV.
PS. The capacitors are usually 680 - 1000 micro farad and 16-35V.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each, depending upon the model.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
Where is the lamp on my Emerson flatscreen tv
What ur tv problems?Tell me,i will tries to help u.Sorry LCD tvs or Plasma tvs don't have lamps.It have floorestscents bulbs tubes that are intergraded inside to the LCD or Plama screen panels itself.
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
I have a Samsung LE32R71B 32 in. A small red light at the bottom blinks but you can not turn it on Can anybody help me???
try factory reset switch tv to standby the info menu mute red standby button go to reset wait few mins then swich on
Aug 17, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
Can you tell me the codes for medion tvs?
go to google search and bring up pc repair doctor
Dec 22, 2009 | Medion MD 30262 32 in. LCD TV
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Dead set,flashing standby led
Have ordered new electrolytics for psu and will overhaul this when parts arrive.
Any further comments thro your site would be welcomed.
Jun 19, 2009 | Medion MD 30262 32 in. LCD TV
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
Electro Med Services...
