posted by g_konst on Apr 30, 2008
I have purchased a 4GB kit (2X2GB) but the motherboard detects only 3GB.
Comment by g_konst, posted on May 22, 2008
the problem is that BIOS detects only 3GB not the operating system. I have updated the bios but didn't work. Do you know about hidden settings of the bios? How can I enter into these settings?
Best Solution
posted on May 01, 2008
The problem is that you are running a 32bit operating system. Due to the 32bit addressing, it can't address more than 3gb of memory. The only solution would be to use a 64bit operating system. Unless you are using very intensive programs though, you shouldn't need more than the 3gbs of memory your computer recognizes. If you must use the 4gbs of memory you can buy this
http://www.bestbuy.com/site/olspage.jsp?skuId=8759293&st=vista+ultimate&lp=2&type=product&cp=1&id=1202650464466
Hope this helps,
Harris
Hope this helps,
Harris
Rating Locked! (?) g_konst has rated this solution as Thanks for Trying
Solution #2
posted on Aug 01, 2008
first you need to update to the latest bios from asus http://en.wikipedia.org/wiki/Asus .
after you have updated go to your system bios. select the advanced tab,
then select chipset then set the northbridge memory remap to enable.
this will fix your problem. any questions
email me
christian@thepcrepairguy.net
thanks!
thanks!
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for ASUS P5LD2-VM Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
P5LD2-VM replaced Power Supply...
now switches off right after... Answer This...
Linspire 6.0 deleted &...
I cannot get my emails and when... Answer This...
Repair Service
Find Motherboard Repairman Near You:
